What does this do?
There is a silver metal pipe next to the throttle body coming from the cylinder head. [U.S driver side]
What does it do and where do I link it to? [think its something to do with water]
Also at the back of the inlet manifold there is a pipe coming off. What does this do?
Water Pump Tap
Upp Radiator Hose Tap Pics 13 and 14
T,
Does this have any negative affects?
Also can someone explain to me what that pipe actually does because on all the other cars Ive worked on steam pipes dont come up?
Way too much information and opinions to rehash here.
I would suggest going to the advanced search feature and search the word steam in the conversions and hybrids subforum.
You will find more information than you can imagine.
I also routed the line from the coolant crossover tube. This tube can be routed to several places. The most popular is to run it to the radiator by the upper radiator hose. Others run a T in the upper radiator hose and routed there. On 5.3L Trailblazers the line runs to the large heater hose. So I drilled and tapped the water pump and ran a stainless hardline from the crossover tube to the water pump.
Andrew
