Which filter to use ahead of Walbro inline pump.
Since I am using an original fuel tank from the 1980's, I want to use a filter before it gets to the Walbro pump. I'm thinking something that I can pick up from NAPA, not Aeromotive stuff. Something to filter debris, but not starve the pump dry. Any suggestions from practical experience?
Any transparent ones for visual indication of reduced capacity?
Any photos of your fuel system installation?
Good luck
Andys
Mallory recommends their 40 micron 3175 filter in front of their pumps here
http://www.malloryperformance.com/pd...m_Products.pdf
The summit pump I bought also recommends a 40 micron filter. I am running a 40 micron I think aeromotive filter, only because it as the cheapest in line filter that had the 3/8 NPT fittings I needed.
Interesting, on the Bosh 044's they say 80-100 while the OEM pumps use a simple in-tank sock filter. At 45 micron, you can hear the cavitation noise quite clearly.
Oh well.
Andy1
http://www.robbmcperformance.com/products/filters.html
Jack
Did you use the 100 micron or 40 micron? Large size or small filter?
I'm thinking Andy may be right, perhaps if I use the finer (40 micron) filter, go with the larger unit to prevent starvation.
The Aeromotive/Earls screen type (cleanable) filters at 100/80 micron are widely used in high performance applications and they work. (i.e. Good pump longevity, easy serviceability, and low noise.)
But, it's your money.
Jack
Yeah Aeromotive recommends 100 micron. And yet the aeromotive filter I have is a 40 micron. Funny how they all recommend something different
Key is just keep the filter clean and you won't have to worry too much about restrictions. Tear up one $250 pump and expensive filters are going to start looking pretty damn cheap.
I used the short 40 micron Part # 1028. I have it connected directly to the sump on my tank, then to a walbro 255 and corvette regulator. I have a rock solid 58 PSI at the rail under all throttle conditions.
Jack
