gauge fittings
Old Aug 3, 2009 | 10:47 PM
crazygn's Avatar
Default gauge fittings
I need to find the size fittings to hook up my water and oil pressure sender. And can i just pull the stock oil pressure sensor or does the pcm need to read this. I guess water temp i can tap the other head
Old Aug 4, 2009 | 07:21 AM
ssduane's Avatar
PCM does not read oil pressure.
I think the water is either a 12 or 14 mm by 1.5 pitch. Each head has a water port, passenger side it to the rear. Not sure on the oil pressure port.
Old Aug 4, 2009 | 11:33 AM
383lt1impala's Avatar
What's the size of thead the one oil pressure sensor the one that goes in the back of the intake?
Old Aug 4, 2009 | 11:52 AM
veee8's Avatar
16mm x 1.5mm oring style is oil pressure
12mm x 1.5mm oring style is water temp
Old Aug 4, 2009 | 12:13 PM
rockytopper's Avatar
You can buy this kit. Equus - Oil Pressure and Electronic Temp. Metric Adapter Kit (9848)
It has adapters that fit both the oil port at the rear of the intake and water port on the aft side of the passenger head. I think the temp gauge needs to be electronic because the mechanical style ones are to big for the adapter and port. I have read that here in another post. I used this kit to install autometer gauge set to the ls1.
Old Aug 4, 2009 | 04:40 PM
Bacon505's Avatar
Speedway Motors sells them also, 182-2277 for the temp sender adapter and 182-2268 for the oil pressure. $9.99 and $10.99
Old Aug 4, 2009 | 05:13 PM
The entire Equus Metric Adapter Kit (9848)
sells for less than 8$ on line.
Old Aug 4, 2009 | 05:17 PM
Bacon505's Avatar
Well, that's a better deal then....I'll keep that in mind when I need the adapters.
Old Aug 9, 2009 | 05:24 PM
69_YENKO's Avatar
good find thanks for sharing that
Old Nov 15, 2009 | 11:33 PM
brando1985's Avatar
I've twisted two of those shitty Equus fittings off in my head. They're very poor quality. I highly recommend spending the extra money and buying the Autometer fittings from Speedway.
Old Nov 16, 2009 | 04:29 PM
69_YENKO's Avatar
for reference the fitting adapters i got from equus seemed well made and went together flawlessly for my project.
Old Nov 17, 2009 | 12:07 PM
digitalsolo's Avatar
The Equus fittings will work, but you must be VERY careful installing them, specifically the water temp fitting. (I've done installs in three cars, and three of them have broken; one by me, one by each person installing them in their cars) If Brando says the Autometer ones are more stout, I'd believe him, he's pretty familiar with Speedway's parts.
Old Nov 30, 2009 | 04:57 PM
H8TO WRK's Avatar
I just broke the Equis fitting for the water temp sender on the weekend. It is weak and did nto take much to break it.
Old Dec 11, 2009 | 04:40 PM
popeye's Avatar
Well..........the boy (foster child) broke mine also, he's was 11. It was the cheapie Equus brand. Just ordered an Autometer adapter from speedway $17
Old Dec 13, 2009 | 09:12 AM
flame's Avatar
My buddies 68 C10 we just took the oil sender out of the motor and broke the sensor off and tapped the base for the 68 sender. Didn't cost anything. For water temp I took a 1/8" to 1/4" pipe adaptor and ran the metric die over it cost 50 cents. Then got a temp sender with 1/8" pipe thread that was as close to the 68 specs and added a couple resistors to make it accurate.
Old Dec 13, 2009 | 02:34 PM
1976CamaroGuy's Avatar
On the oil sender couldn't you tap the fitting on removable piece on the oil pan, on truck applications this pieces was a "blank" plug and let you tap whatever thread you need and they were interchangeable across oil pans.
On the water temp, you can buy one of these Flex a Lite radiator hose adapters and grab your steam line location and temp sender location in one shot.
