Why doing a leak down test is important. - My results
Old Nov 20, 2003 | 05:58 PM
99 Black Bird T/A's Avatar
Default Why doing a leak down test is important. - My results
If your looking for a core and want to avoid problems like the one I've got for my LS1 swap, I would recommend contacting SpearTech as their driveline packages are tested.
Here's the data on my leak down test on my LS1 core I'd planned to use in my 91 RS
Front
42 ... 10
30 ... 12
12 ... 20
20 ... 10
It's got issues.
Suggestions on what I need to have done when it's apart being re-ringed/honed etc.
All comments welcome
Old Nov 20, 2003 | 06:15 PM
jsworkstd's Avatar
I'd just tear it apart and check it out. I've found stuck rings, or rusty valves, especially if it's been sitting, both of which will cause leak down. Probably only needs hone, rings, lap valves. The gaskets will probably cost more than the parts it needs. At least you'll know what you've got.
jeff
Old Nov 20, 2003 | 06:41 PM
John B's Avatar
Moderator
Clevite77 bearings, ARP 2000 rod bolts, verify crank endplay and reluctor wheel run-out, balance assembly and match head gasket thickness to obtain proper quench distance.
