1st startup.......need help
I checked that the power is comming into the cabin and the thick yellow wire going to the ls1 relay is getting power in start position. I can also hear the TPS housing click. but nothing else. no power to the starter.
i have not tuned the pcm for vats or anything else but I think i read somewhere that even without removing vats the engine should turn over at least for a sec or so. is this the case?
.I am sure it was one of the things u guys suggested just dont know which one ..
So thanks again and cheers !!
.Next I am gona try to see if I can get the oil preasure up. I dont have a universal gauge just the stock 82 gauge cluster . I hope I wired it right and it shows some preasure.
I filled oil in the new filter based on reading on here. then even though the engine only takes 5.5 qts, i put a total of 6 qts including what I put in the filter.
Anyone know what the voltage should ahow on the oil preasure signal wire on the LS1 harness? its a 02 TA harness. ?????????
I am not sure I am getting oil preasure and still no way of checking it. i am still tring get enough info to re-pin my gauge in my 82 ta.
I tried using a DMM but either i am not using it right or its not reading right.
I put it in the 200 ohm setting.
key off : +ive 5-8 ohms
Key on: -ive 110 to 122 ohms.
during cranking : +ive 50-121 ohms.
i took the fuel pump fuse off, to the coil connector and put the ign in start. i would say 6-8 times at 10-15 sec intervals. each time same result.
what can i do ?
I also need to do the drill and tap mode on the ls1 sending unit.
I was hoping in the mean time, I should be able to use a DMM to measure resistance from the LS1 sending unit already on the block.
what reading should I be seeing ?
Just one wire. Same wire my previous '88 TPI swap used.
After you've traced and verified the wire, see LQ9Chevelle's comment. You'll have to crank it for quite a while to build oil pressure, and even then at ~150rpm cranking speed it's unlikely to be enough to move the gauge.
I hooked up the tan wire comming from the LS1 Oil preasure sender at the back of the engine to the 1991 gauge (thru the C100 bulkhead connector on the firewall)......no reading whatsoever.
So I was guessing that I need to change the LS1 sender to a 91 sender using an adapter.
Is this not the case ?
I redid the pins still no reading.
First time I am reading that a LS1 sender will work with a 3rd gen gauge.
