A-body headers on the cheap! Check it out
Dave
Using BBC with the LSx flanges has also been done, a plus is that BBC header usually have the larger primary tubes.. Many of the Fox/Mustange's have been using this method for Fox Body headers with LSx swaps.
Truck header are not a good match, the rear exit will point to the Firewall and Vette ones will point into the X-Member.
But as with all swap headers.. it all depends on which mounts and/or where you locate your engine as to if your going to have any clearance problem, but in general, they do fit. Also, IMO, If your F-body OEM Exhaust Manifold will fit, then generally F-body Headers should fit as a general rule of thumb or is a good starting point.
