how do I attack the spark?
Old Aug 12, 2009 | 11:29 PM
71 chevy's Avatar
Default how do I attack the spark?
I have a megasquirt 2 v3.0 that I am currently using on my bbc and love.
I would ideally like to keep it but nothing is set in stone.
my problem is : I was gonna use the msd 6010 for the spark but the more I read about it, the more I want to stay far, far away from it.
what are the other options. obviously, Im looking for something inexpensive if it exists. I would like to be able to tune too.
ford edis?
distributor?
modded stock computer?
what works for you guys and how much did it cost?
Old Aug 13, 2009 | 05:43 AM
LS1MCSS's Avatar
If you have a good battery and starter, you shouldn't have any problems with the 6010. A lot of the starting problems were because the engine didn't crank over fast quite enough for the box to realize the engine was cranking.
Old Aug 13, 2009 | 06:07 AM
Pop N Wood's Avatar
Besides they seem to have fixed most of the problems with the box not firing at crank.
FAST makes an iginition box. A good bit more expensive than the MSD box.
Why can't you use the megasquirt to fire the ignition? I thought they had that option.
Old Aug 13, 2009 | 08:13 AM
71 chevy's Avatar
it does have that option but It only has two piddly drivers and I have heard they are not up to the task of firing 8 coils sufficiently espe at rpm
do you know a pn for the fast box?
lsmcsss - it seems everyone who has owned one has hated it - plus they say it dies at 5800 rpms
Old Aug 13, 2009 | 09:07 AM
71 chevy's Avatar
also, has anyone successfully used a ford edis8
Old Aug 13, 2009 | 10:48 AM
Pop N Wood's Avatar
In think this is it
http://www.efisupply.com/FAST/xim%20dist.pdf
The MSD 6010 boxes have programable rev limiters. i can tell you for a fact they are good up to 6300 RPM. My dash tach was off and I hit the rev limiter the other day.
Old Aug 13, 2009 | 05:03 PM
71 chevy's Avatar
In think this is it
ok, looks like the msd is back in play. how do you find the ease of tuning?
Old Aug 13, 2009 | 05:08 PM
xpndbl3's Avatar
i ran my 6010 box to 7200 rpm with no problems.
Old Aug 14, 2009 | 12:23 AM
71 chevy's Avatar
great to know. thanks
Old Aug 14, 2009 | 07:09 AM
Pop N Wood's Avatar
Once you get the lap top to connect it is just moving dots around on a map. Extremely easy.
Read through this thread. Lots of good info. Just make sure you get the MSD box and not the edlebrock box. The MSD can be tuned with a lap top where as the edlebrock is just through pills.
https://ls1tech.com/forums/conversio...-dist-ls1.html
Old Aug 14, 2009 | 09:30 AM
6.0Nova?'s Avatar
You can run the stock LSx ignition with the Megasquirt, there is a guy on here with an 8.1 big block in a 69? Chevy truck and he has done it on several engines. Below is some useful info on doing it.
http://msruns.com/viewtopic.php?f=84&t=22474
http://msruns.com/viewtopic.php?f=84&t=22863
