'00 S10 4.8 Dyno Results
Ok here it is:
Stock 4.8 w/Sanderson shorties, 2.5" y-pipe to 3" cat and pipe through a Dynamax muffler. Built 4L60E and built rear w/3.42 and eaton posi.
97* out and no humidity.
Dynoed on a Dynomax loaded dyno (similar to mustang dyno).
Numbers are:
Tuned by Ryne at CMS in Lake Elsinore.
A/F ratio:
I personally think it's not that bad for the smallest genIII LS motor and 140*+ IAT's (nothing I can do about the IAT's either).
So lets hear what everyone else thinks!
Numbers are:
A/F ratio:
I'd go with something a little bigger on the cam. Your best bet would be a nice turbo setup, then maybe I could see the LS6 cam.
I know other cams will pass smog also, but you cant beat LS6 cam and springs!
