help with engine stands
Old Aug 13, 2009 | 05:38 AM
drv's Avatar
drv
Default help with engine stands
What is the difference between the sb and bb engine stand in terms of engine position. Yes I have used the search future. will appreciate the info
Tony
Old Aug 13, 2009 | 05:53 AM
Bowtie70SS's Avatar
In a 70 Chevelle nothing, the stands are different for a 307 and a 350/396/454 but other than that there is no other difference. The six cylinder is a different story though. The big block and small block have the same distance from mount to bellhousing.
Old Aug 13, 2009 | 08:27 AM
fasteddy51's Avatar
I have been searching the same thing. When refering to the 68-72 Chevelle and the 70-72 Monte Carlo V-8 frame stands, the parts that bolt to the frame crossmember were offered in two different types like Bowtie70SS said. The 350/396/454 stands are the same, with the 307 different for some reason. I found a picture on here somewhere where someone compared the difference. There is a "Short and Wide" version, which should be the 350/396/454 style, and the "Tall and narrow" version, which is the 307 style.
The Short and Wide version takes an engine mount that is 2-5/8" wide inside clearance (engine mount slides down over the top of the frame stand), the Tall and Narrow version takes an engine mount that is 2-3/8" wide. There is also a difference with the actual bolt location that bolts them together. The Short and Wide version has the bolt centerline at 1-1/4", while the Tall and Narrow version is at around 1". Stealth71 had some excellent pictures explaining this that I will try and attach. Good luck
Old Aug 13, 2009 | 11:38 AM
drv's Avatar
drv
Sorry but should have told you guys I am working on a 69 camaro with an lq4 block and f body accessories. I search on Stealth71 post a there is a ton of information but related to chevelles.
Tony
Old Aug 13, 2009 | 11:43 AM
bczee's Avatar
Also, you also have to note that the BBC were offset to the right a bit for clearance issues (as compared to SBC that were pertty much centered in the frame.).
Old Aug 14, 2009 | 03:57 PM
Rodder's Avatar
Info on 1st gen camaro mounts and stands is here:
http://www.pozziracing.com/camaro_engine.htm
