LSX in a foxbody question?
thanks
Josh
http://www.lt1swap.com/underhoodfuseblock.htm
For wiring up the Ignition switch, the yellow wire is what feeds 12v to the ign. switch. The Red/Ltgreen wire is what is hot in run/start
. You will need to know that when you start to fit your wiring harness and fuse box. thanks
Thanks
Josh
Thanks
Josh
thanks
Josh
Carb and front mount distributor for the win. All i did was jet it and time it and have not touched anything in two months i love it. If your thinking of buying the Kooks headers DON`T they suck.
thanks
josh
Kooks phucked up when they made the jig for the headers. It don`t matter witch trans cross member you have wheather it be a stock one or a AJE cross member you can`t use it. The headers dump right at the cross member so it was impossible to use the AJE trans cross member for my th350 so i had to have one made. Also the steering shaft that came with the flaming river manual rack hit the headers. I had to cut the steering colume shorter so that the top knuckle on the steering shaft ended up closer to the fire wall. Also on the passenger side i had to take and put a real big dent in them to clear something that i should not have had to. I geuss its better then spending $1,000 on having custom headers made maybe ? I did get lucky and on the Corvette forum one of the sponsors had a sale on Kooks headers and i got mine for $562 shipped.
