slave cylinder
Old Aug 19, 2009 | 08:54 PM
Redrumls's Avatar
Default slave cylinder
Who makes a good bracket for this or a master cylinder for my clutch set up?
Its for my 68 camaro swap.
Old Aug 19, 2009 | 09:14 PM
bczee's Avatar
what engine and trans are you planning on using ?...
Old Aug 19, 2009 | 09:18 PM
jomomma's Avatar
i got my bracket from street and performance
Old Aug 19, 2009 | 09:30 PM
Redrumls's Avatar
6.0 with Muncie behind it. I just need my clutch set to be done with the tranny aspect or the swap.
Old Aug 19, 2009 | 09:36 PM
Redrumls's Avatar
I need the bracket for the firewall, a good one. I'm going to make the one for the bellhousing for the slave.
Txnx for any info
Old Aug 20, 2009 | 09:41 AM
bczee's Avatar
The bracket that everyone is using is marketed by both ATS and S&P, I think ATS own the design. The Template can be found on the S&P web site.
http://www.hotrodlane.cc/Streetstori...ls1camaro1.htm
I used it to make mine. I used 1/4" steel but I would recommend 5/16" if I did it again.
You may not need this. The reason it has to be used on the A, F and X body, when using the 4 Gen F-Body master is that the mating surface of the Master and the Firewall do not allow the correct angle and is mis-matched by 20-23 degrees. Your master that your using is designed to mate to a flat firewall.
Why do you think you need this bracket ?
Old Aug 20, 2009 | 01:35 PM
Redrumls's Avatar
That's what I was looking for, the flat mounting bracket. I seen some & I'm just going to make one. Looks like I'm going to have to redo brake line, they are right in the way where I have to mount master cylinder. Always something, hope all this work is worth it.
Old Aug 20, 2009 | 05:24 PM
bczee's Avatar
Let us know what you come up with (Pictures) !
Fyi.. that bracket is designed with a 20-23 degree bend in the middle. but you should be able to bend it to what you need.
Old Aug 20, 2009 | 07:15 PM
Redrumls's Avatar
Tnx for the info, I'll get some pics up when I start doing the intall.
Old Aug 21, 2009 | 02:15 AM
Redrumls's Avatar
Looks like slave cylinder is a pull type, gonna be a bitch to mount my muncie. Got it from a friend, gonna have to figure out a way to mount.
Any info would really help! I truly rely on these forums for advice!
