LS1 Notchback FoxBody = 2140 lbs complete
I dont have a final race weight as I didnt finish the car till Friday morning at 4:30am in the morning...went home and got 2 hours sleep, loaded the car up and took to the alignment shop at 7:30am. Brought back to the shop and unloaded it and gave it a quick check over, drove it around the parking lot.
Loaded it up and took it straight to the track. I had never had the car above 10-15 mph, didnt know if the tranny would shift, it would drive straight or if the brakes were good....first pass rolling in it off idle and shifting at 5500rpm soft went 11.02 @ 124
Ran 10's the rest of the weekend @ pinks all out with no problems. Scale at the track said 2720 with me in it. That was with me (about 220-225), helmet, helmet bag with big fire extinguisher in it, laptop setup in backpack for logging and full tank of gas every pass.
So im guessing the car to be about 2480 finished as it sits which is more than I originally guessed.
First pass video (havent gotten others from people that were recording it yet):
http://vids.myspace.com/index.cfm?fu...deoID=63118312
![Name: scan0001.jpg
Size: 170.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/621464d1501360366-ls1-notchback-foxbody-2140-lbs-complete-scan0001.jpg)
DA was 4100 feet on my fastest run (102 degrees out and humid) (125mph):
Time corrects to a 10.38 @ 131.31
Car is losing alot on the stock MAF, crappy air intake, no tuning (just a guess base tune running 26 degrees and 1.270 in the PE table across the board, horrible DA weather, only 3.73 gear /w 28" tire, tight n20 converter, only 4 passes on the car, victor jr style intake setup for the F2 procharger thats going on with the 440" LSx motor instead of ported 92/92 setup (list goes on and on)
I couldnt be happier
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Your times dont seem to correlate with your weight.
My car has a 3000lb race weight with just a ported tb and 1 3/4 long tubes with full exhaust and I'm pulling the times in my sig.. just figuring the car out. The car is manually shifted and has 11.40s in it in the heat..
I dont know man. I've never heard of a 2200lb mustang and if you h/c combo is working well then at that weight you should be moving much quicker.
If I could get my 71 nova to 2700 race weight I would be thrilled. as it sits, its around 3200 so it would take quite a bit of doing to get there. I think I can get to 2900 easy. the last 200 lbs would be the hardest.
now, a 63-65 chevy II, they came from the factory around 2500lbs :jealous:
#33
#34
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
http://www.novaresource.org/weights.htm
I did, however, weigh my 71 with an all iron bbc, steel wheels,all iron body, but manual everything, and no air etc, and it came in at 3260lbs without me. thats before I removed the inner fenders(24), nitrous stuff(35), heater core and related, hood latch and related, dual exhaust etc. In total Ive removed around 230lbs of stuff since I last weighed it, and Im expecting the 5.3 to be at least 200lbs lighter than the all iron big block, so Im looking at around 450 weight savings since I last weighed it.
I think with aluminum wheels, skinnies up front, pin on glass hood, trunk lid and bumpers, it should be in the 2600lb range without the driver.
#38
i have a 87 coupe with a iron block 6.0 all the heater stuff windshield wipers two front seats door panels and so on....i have'nt put the roll bar in it yet but as it sits now 2380lbs w/o me in it....so i beleive what he's saying about the weight of his car...
#40
Going out again this coming fri/saturday for the West Coast Hot Rod Assocation (WCHRA) race...
I hope to be posting a fastest stock shortblock LS1 record (9.50 pass /w spray) and
10.40-10.50 on stock 5.3l heads this time out.....
Ive got my plan laid out to go 9.81 on the motor within a month or two and hopefully break Texas Speed's fastest stock shortblock N/A record (9.82)...
