Help me determine what year LM7 this is.
Old Sep 10, 2009 | 07:32 PM
PedaltoMetal's Avatar
Default Help me determine what year LM7 this is.
I picked up a complete LM7. Was told it was from an 01 and had been sitting for a year. It is a DBW set-up so I start looking for TAC modules and pedals. Well I come across speartech's website and they show the TB I have is for 03+ trucks. Also my ECM connectors are green and blue indicating 03+. Block casting number just indicates 99+ iron block. Is there an actual date code on the block somewhere? The TB is stamped with an "03" but I don't know if thats the year or a shift code. I'm hoping it is an 03 maybe that'll make finding TAC's and pedal's easier. So am I right?
Edit: also forgot to mention that it has the regulator and return line on the intake fuel rails.
Old Sep 10, 2009 | 08:30 PM
Bo185's Avatar
I don't think the LM7 went DBW till 03. Unless the Caddys that had the 5.3L had DBW as some Caddy Escalade had a 5.3L as a base motor as well.
But looks like an 03+
Old Sep 10, 2009 | 09:52 PM
Thanks. I'm leaning toward 03 as I learn more about these engines. Also heard that the flex fuel engines got Denso 33# injectors and the gas got Delphi 28# injectors. Mine say Denso on them. Is there a way to confirm this? If it happens to be a flex fuel engine, is it still an LM7?
Old Sep 11, 2009 | 12:25 AM
cutlass_455's Avatar
Dont these engines have a VIN sticker or something on the head?? Get the VIN, got the year.
Old Sep 12, 2009 | 11:49 AM
busta9876's Avatar
blue/green pcm is for sure 2003+
Look at the fuel rails, one line or two?
2003 was still supply/return fuel rail
2004 was return-less
flex fuel injectors are a square connector (rounded corners) 5.3L L59
non-flex fuel injectors are more rectangle in shape. 5.3L LM7
good luck.
Old Sep 12, 2009 | 04:07 PM
Thanks for the reply's. It's an 03. It has the return line on the intake fuel rail. I think it's flex fuel because somewhere I read that FF trucks had Denso injectors and gas had Delphi. Mine are Denso.
