Fiero manual steering box/rack?
When I swapped the first v-8 into my racetruck I just blocked off lines and capped the sterring box lines. I read on here somewhere that you could use a Pontiac Fiero manual box/rack for weight reduction on race or track cars?
I would like some more info on this. Is the Fiero a man. box, or a man. rack? I want to get the bulky power steering box off the front of the truck. Thanks for reading
-SS
-SS
So, I guess I'll just look for a manual steering box from an early S-10. I was just wondering about the possibility of using the fiero man. stuff. I hadn't had any luck peviously locating a man. box for S-10's. Thanks for the reply NemeSS!
-SS
-SS
I saw one guy from Ontario post on MalibuRacing.com that he put a Fiero rack into a G-body with very little fabricating. Unfortunately he vanished from that site without ever giving any details.
The manual S-10 steering box (with pitman arm) is a bolt-in for gbodies so they come up for sale for $60-$100 regularly on the site I mentioned above.
84-87 Fieros are essentially rebadged Chevettes
88's are the only oddballs for their short run
http://www.thirdgen.org/techboard/su...-rack-3rd.html
It weighs 12lbs
Easiest for a rack truck would be the Manual S10 box as its a direct bolt in
It weighs 12lbs
S-10 box.
-SS
http://www.wilwood.com/Start/Product...1-RP/index.asp
here is a link to wilwoods reproduction pinto rack, there is another link off that page to a technical drawing with all dimensions, might help you see if it will work or not.
I used to work for a rack & pinion supplier. We sold a ton of Pinto/Mustang II manual racks for custom jobs because they are so light, and have 2 very simple bushings so that it can be adapted to almost anything. And you can buy it from a regular parts store without race car prices.
Ask for a manual rack for a 1975 Mustang II, and look at the pictures.
