Lt1 or LSx in Audi A6?
Kennedy Engineering is now making a adapter for the LSx motors and in the link below the builder got a LT1 kit from Kennedy and mated the LT1 to an Audi 5000 transmission.
The A6 is quite a bit bigger than the A4 so I'm assuming the issue of the motor being longer shouldn't be such a big deal in this case. At least not like it would be with an A4.
IF I ever do this I would love to keep the quattro system in tact.
This guy mounted an Audi 5000 trans to an LT1, although that was for a Fiero application.
And how would I wire it? Would I use the LTx/LSx harness and wire that into the Audi computer or use the GM computer somehow wired into the car...
As far as wiring is concerned, use the LS computer and mate it to the audi car. Basically, like any other swap into a foreign engine bay (any engine bay that the LS doesn't "factory" belong). I would imagine that the engine bay size would be equal to that of some of the BMW swaps found on here.
Anyways, anything can be made to work. It may just take a little longer and big $$$ to make it look like it belongs and works together.
IF you want to go fast in an A6 get a 2.7t and some KK04's or GT25's.
The automatic will break.
The manual gearing is all wrong. I make 17lbs of boost with my A6 and first gear is totally useless. Now its AWD so it goes but its way too short for the torque makes.
You have to see a 2.7 or a 3.0 out of the engine bay to understand how small it really is.
The 4.2 isn't much bigger.
The problem with Audi's is the engine site forward of the front axle.
They are nice cars but horrible dynamically and hanging that much weight off the front end makes them handle poorly. Audi does a lot to get around it but in the end they oversteer and push.
A lot of what Audi does to improve the handling makes them do odd things. A4's are very pitchy on the freeway and there is no fixing it.
If any swap I'd ever try is to put a 2.7t motor in a new B6/7/8 A4.
Oh and the electronics will be a nightmare. VAGcom controls all kind of specific things outside of the OBDII stuff.
Well said, I drive a 2.7T auto with the tiptronic and completely agree that putting in an LS series would be an absolute nightmare without having to rewire a good portion of the car.
I like our Audi's but they are not a good swap candidate.
There are plenty of things to like about them and plenty of things to hate.
Try swapping out a steering rack in a V6 Audi...in a 4 cylinder is a 2 hour job, tops...in a V6 its about 12.
They redefine tight packaging and suspension parts are 40K interval service items but that is consistent with all German cars.
It has its uses...it runs low 13's in the 1/4 in the dry and I bet with snow tires it runs a high 13 in the snow.
The car is silly in the snow with good snow rubber, its a 4000lb ralley car, especially one without ESP where the gas pedal does what you want it to do regardless.
-paq-
Eric www.kitcarchassis.com
can you link me your build plz? I really would like to see that
Haldex doesn't exist in longitudinal cars, and I'm not using the stock a4 diff either. I'll show you why, I haven't taken any pics of it lately but basically the snout of the diff is like 2 feet long and the diff itself is tiny. For the price of a limted slip for the a4 I can get a full built to hell 8.8 IRS center section!
