Malibu 80
Old Sep 30, 2009 | 01:48 PM
hunterdavidson's Avatar
those trans dapt plates were they one inch set back.
Old Sep 30, 2009 | 06:02 PM
Roller406Bu's Avatar
Originally Posted by HILROD
I used Trans Dapt plates with stock mounts. One tube on the pass side needed clearance. The lower mounts neede to be moved up around 3/8 on the frame on each side.
what he said, and tci makes a flywheel with the spacing built on to it so you can use a reg style convertor...I used a ls specific style convertor on mine with the stock flywheel..
Old Sep 30, 2009 | 06:05 PM
part number is 4592
Old Sep 30, 2009 | 10:19 PM
HILROD's Avatar
I don't think they are setback plates. I used mount plates 4572.
Old Oct 1, 2009 | 05:30 PM
thanks for all the info. Ill probably be starting in the next week an ill keep yeah posted. Good luck to eveyone else!
Old Oct 19, 2009 | 07:39 PM
The flywheel you are talking about what is the part number to it. If there is any other combinations for a flywheel that will work with a th350 what are they. Thanks
Old Oct 20, 2009 | 08:25 PM
Kevin Winstead's Avatar
It's TCI part number 399753. It works great on an application that has a traditional small bolt pattern converter.
Old Nov 10, 2009 | 08:20 PM
do yo have to run a oil coiler on these motors or not. If not what do you do to plug them off. Also the line on the water bypass on the front of the block. Do you cap it off or what do you do. Thanks
