Porsche 911 LS1 Swap need Help!!
Old 02-16-2010, 11:23 PM
shanghai_todd's Avatar
Here is a pic with the new intake
Old 02-17-2010, 09:59 AM
cam
cam's Avatar
Its very rare to have PCM troubles with these set ups. I suspect something physical is wrong with the assembly/harness or a mismatched sensor etc.
Who did your wiring harness?
Old 02-17-2010, 12:15 PM
CODE4LS1's Avatar
Have you tried disconnecting the MAF to see what it does in speed density mode?
Old 02-17-2010, 04:27 PM
Pocket's Avatar
LS1Tech 10 Year
Before you go suspecting the PCM, do a continuity test on the IC 4 and IC 7 wires from the PCM connectors to the coils. A bad ground will kill the coils on a whole back, not individuals on opposite sides
If the PCM pins are correct, check the coil connector pins for IGN 12v, GRD, and low ref continuity
If all of those check out good, look into the PCM
Old 02-18-2010, 12:02 AM
gnx7's Avatar
LS1Tech 20 Year Member
swap looks like it should be a blast. Wondering how the 915Transaxle will hold up? The upgraded body looks great too!
If there is anyway to get a straight shot into the throttlebody it is essentially free HP. That crazy 180* turn is ultra restrictive not only with the major turn but the necked down inlet. Since you are DBW you could have an aluminum 90* elbow fabbed up that is even sized throughout and then bolt the TB to the that effectively allowing more room for the "turn."
Old 02-27-2010, 09:57 AM
Jimbo1367's Avatar
LS1Tech 10 Year
updates......?
Old 04-24-2010, 04:47 PM
Update: Problem Found
As I suspected I inspected the reluctor wheel today and discovered that it is bend and has several teeth that are chew'd up and mis-aligned
Any way these can be fixed without dropping the motor?
Attached Thumbnails Porsche 911 LS1 Swap need Help!!-reluctor-wheel-bend.jpg   Porsche 911 LS1 Swap need Help!!-reluctor-wheel-tooth.jpg
Old 04-24-2010, 09:36 PM
Pocket's Avatar
LS1Tech 10 Year
Its pressed onto the crank
While the crank can be dropped out the bottom it is a royal PITA
God, I hope my reluctor isnt screwed because Im having similar problems, except my misfire occurs randomly across all 8 cyl
Old 04-25-2010, 01:06 AM
1dirtyZ's Avatar
what caused it to loose those teeth?
Old 06-10-2011, 05:44 PM
TipsyMcStagger's Avatar
Bump to find out if you've got it squared away?
Tipsy
Old 06-11-2011, 03:56 AM
RATBOX's Avatar
That is such a badass swap, can't wait to see videos when it's done.
Quick Reply: Porsche 911 LS1 Swap need Help!!
