question on power steering hoses???
Andrew
I bought braze or weld-on AN-6 male adapters for hard tube for about 50 cents each from hosepower.com
I cut the factory fitting a couple inches down form the fitting and silver soldered the An-6 adapter to it.
I plumbed the low pressure lines with 3/8" aluminum tube flared with a Parker Rolo-flair tool and used JIC 37deg steel fittings
For the one piece of high pressure line to the rack from the pump, I'm either going to buy one from the local hydraulic hose fab shop or get one off of ebay (search AN-6 hose). If it ever blows, I just need a replacement hose I can get at any hose shop. Whichever route you go you need to make sure the hose can take 1500 psi (i think the relief is set at 1200 or so on most TC pumps)
There are -6 adapters for the sterring box. The return side can be regular -6 hose.
Much better looking than any NAPA hose.
