one radiator fan or two?
Old Oct 9, 2009 | 02:11 AM
theomms's Avatar
Default one radiator fan or two?
I see plenty of people running either one or two fans on their swaps.
Why would a person prefer one setup over the other?
sound level?
power draw on the alternator?
cooling ability?
Not sure why people go one way or the other.
Old Oct 9, 2009 | 04:29 AM
poconojoe's Avatar
Sometimes its a fit issue, other times its a cooling issue, but I prefer two fans, since on low paeed you can run them in series and its a lot quieter, plus wired in series, they're alway drawing air over the whole width of the radiator
Old Oct 9, 2009 | 04:34 AM
ramdaspadhye's Avatar
the more cmf your fans pull as a whole = better cooling... If you can fit 2, go with 2... make sure you get a quality fan, too. Lots of r&d goes into blade pitch, which = more efficient fan.
Old Oct 9, 2009 | 09:50 AM
S10xGN's Avatar
I'd try for the best core coverage you can get, either two small or one large depending on the core size. I used a single 16" (from my old Buick GN) and have no issues with cooling. That's on a Jeg's dual-pass 16" x 22" core with A/C and a huge trans cooler in front of it, SE TX heat and humidity to boot!
Old Oct 9, 2009 | 11:31 AM
Stu Cool's Avatar
Depends too if you are running Air Conditioning. With AC it is a good idea to have a second fan that comes on with the AC or when the AC reaches a certain pressure level. You can control that with a trinary switch. For basic cooling I run a single 14 inch Spal type fan and it works fine, though you can definitely hear it.
Pat
Old Oct 9, 2009 | 11:55 AM
ssduane's Avatar
like all stated above, running two gives more surface cooling area, and if you wire them in with the PCM they will kick on low speed (both) at a preset PCM set temp then high speed at another preset. For one thing, its quieter as most rarely come on high speed at idle and another thing is if wired in with the PCM and you have AC, they come on low speed when the compressor clutch is energized.
Old Oct 9, 2009 | 01:04 PM
Pop N Wood's Avatar
The trick is just finding something that works. I have a two speed Taurus fan, but don't have the high speed setting hooked up. The low speed setting is all I need. Most people seem to get by with just the low speed.
I went with the Taurus unit because it is a good fit with my swap and you can't beat the $20 pick and pull price.
Old Oct 9, 2009 | 05:27 PM
Andy1's Avatar
For those of you that use the PCM to control your fans, what fan-on and fan-off temps for both low and high speeds did you program your PCM to?
Thanks,
Andy1
