Lq4 in 52 Chevy Truck project
#41
They are supported. Someone sent me a PM regarding my pedal assembly and this was the only photo I had. The photos above were initial install pics. I fabed a firewall mounting plate and a internal brace tying the two pedal assemblies together that bolts under the dash.
The following users liked this post:
T.Bone (02-07-2024)
T.Bone (02-07-2024)
#44
love the project. I had the same plan. looked and looked for a truck trying to find a running driving truck to do the transplant then work on the rest over time. Realized everything was either junk or too high and I wasn't gonna be happy with anything but starting from scratch and doing it my way so the project is postponed. I just dont have a good place to do the work right now. So i'm gonna sell some of the parts I had gathered for my engine build.
#45
#48
I finished boxing in the frame this weekend and finished with POR15 and a top coat of black epoxy paint. It turned out better that I thought it would. I hope to have the fuel tank mounted this weekend and start plumbing the fuel lines. The frame is flipped, upside down in these pics. I also attached a photo of the under side of the cab. I hope to have the lq4 fired in the next three weeks.
![](http://i823.photobucket.com/albums/zz153/52Rat/IMG_0400.jpg)
![](http://i823.photobucket.com/albums/zz153/52Rat/100_0200.jpg)
![](http://i823.photobucket.com/albums/zz153/52Rat/100_0201.jpg)
![](http://i823.photobucket.com/albums/zz153/52Rat/100_0203.jpg)
![](http://i823.photobucket.com/albums/zz153/52Rat/100_0205.jpg)
#52
I finished the fuel tank install and got everything painted. I cleaned the engine and got it back in the frame. The fuel line frame tabs should be here today so I hope to have the fuel lines ran and connected by the weekend. I sent the ECU off for a custom tune. Getting closer to starting the engine.
#54
I received the headers back from Nitro Plate and they look awesome. The quality of the coating inside and out is amazing. I will get some pics when I get them installed. I decided to go with stainless studs and stover nuts to lock the headers down. To give you an idea of how much I saved over ARP. The ARP stainless header stud kit was around $100. I went to the local fastener supply house, picked up some stainless M8 studs and stover nuts; total cost $12. Now I can start building my exhause.
![](http://i823.photobucket.com/albums/zz153/52Rat/NitroPlateHeaderCoating.jpg)
#55
I installed the headers and noticed some of the plug wire boots are on the header tubes or very close to touching. I had not planned on purchasing plug wires but I guess I will. I'm looking at the MSD32829's that allow for the boot to be bent to a 45 degree angle.
![](http://i823.photobucket.com/albums/zz153/52Rat/Header5.jpg)
![](http://i823.photobucket.com/albums/zz153/52Rat/Header3.jpg)
#59
i am going to look at a 54 this weekend. I am just about finished up with my 69 firebird with its 5.3L. Haven't even finished and I'm itching for a new project. Damn i hate this addiction...
