o2 sensor pic request
Old Oct 14, 2009 | 01:01 AM
RPD_Vette84's Avatar
Default o2 sensor pic request
tryin to piece together some parts and havin some issues. i bought a set of o2 sensors for my swap but i think cause my harness they wont work.my motor is a 5.3l but i think my harness is from a 6.0l
is there a difference in o2 sensor plugs from a ls1,lm7 and lq4 harness? any pics of the plugs? oh its for the front set, the rears got deleted out.
Old Oct 14, 2009 | 02:10 PM
BBPanel's Avatar
Veteran: Marine Corps
I have O2 plugs that are 4-pin in a square and my harness requires 4-pin in-line. What is your configuration? Maybe a swap? -Bob
Old Oct 14, 2009 | 02:32 PM
i think i might have the same as you.
the ones i have look like this. (i did notice that the harness that goes to the rear has this style)
i think i might need this style
Old Oct 15, 2009 | 03:41 PM
does anyone know how to rewire it so i can use the square plug?
Old Oct 15, 2009 | 09:39 PM
BBPanel's Avatar
Yeah, I have the same as you - can't help on the re-wire. -Bob
Old Nov 9, 2009 | 06:48 PM
jetback73nova's Avatar
I would need to check my wireing harness but, i know i have different plugs for the front and rear o2's.
I have 4 o2's thatg look like "D" in the above picture (the end looks like the opposite ,mail version of what you have RPD_Vette84). I also have 2 o2's that look like the second ones you posted. I think I need eather the ones you say you have "E" in my picture or i think "C" in my picture depending on which ones are the front two on my harness. I would be up for a trade or sale
Old Nov 9, 2009 | 07:34 PM
FoFittyFoSS's Avatar
I might be a dumbass, but, I'm looking at my harness and only see 3 O2 sensor plugs. 98 harness, completely untouched so far. Any thoughts? Sorry if this was a hijack.
Old Nov 9, 2009 | 08:41 PM
LS1MCSS's Avatar
You're missing something or someone cut one out.
 Michael S. Palmer
Old Nov 9, 2009 | 09:29 PM
psiconversion's Avatar
LS1Tech Sponsor
Be careful, the black square and black flat O2s will interchange, however, the gray/white squares will NOT. Gray/white squares were used on the green/blue pcms and are grounded through the PCM. The black square and black flats (just like those used on the LT1s) are grounded through the case of the O2 sensor and are used on the 411 and other red/blue PCMs.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 10, 2009 | 01:01 PM
how do you know the color of your PCM (Green/Blue VS Red/Blue)
Old Nov 10, 2009 | 01:09 PM
LS1MCSS's Avatar
That's the color of the harness connectors, where they plug into the pcm.
