Tach output looks DEAD.
I read that, since this is a 9 (or so) volt square wave signal, I should be seeing around 4.5 with my voltmeter, but like I said...I'm only seeing .02 or so.
I have no reason to suspect a problem with the PCM as the tune was done by SpareECM and they do this sort of thing all the time, but I suppose it still could be... (Can you even shut the engine speed output off in the tune?) The Tune in question is just a basic 2007 Silverado 2500/MW3 (NV4500 5-speed) with the VATS, EVAP, secondary O2 sensors and Torque management turned off. The engine seems to run perfectly.
Could this be a problem with my digital voltmeter? It's nothing fancy--just a cheap Radio Shack one.
Thanks,
Jake
I'm assuming that even if everything was working correctly I'd need a pull-up circuit to get it to register on my tach because it needs a 12V input. Perhaps I'll just try that and see if I get anything. From what I've read on here, you just connect a key-switched power source/680 Ohm resistor to the tach wire...Right?
Thanks,
Jake
Hope this helps someone else,
Jake
Here's an article to guide you, scroll down till you see the pull-up resistor part, ignore the diagram labeling as this isn't for a tach hookup, but will help illustrate what needs to be done:
http://www.msextra.com/doc/ms3/ignition.html
I have used this technique multiple times, with no PCM failures to date. The oldest swap I have running around is around 3 years, daily driven.
That instruction link I provided was straight from Megasquirt. Surely if this causes problems with the PCM they would have known by now.
Thanks for this thread and the help 96gt'.
I have a VDO tach I brought back to life with a 1k ohm resistor. The issue is the tach reads low (abotu 750rpm low @6k), and is slower to react than my Summit gauge I have as a back up (Summit is too large to fit the space though) I have seen a few threads where people with VDO tachs are experiencing the same issue.
SO my question-
1) Would wiring MORE resistors to bump the signal help more? Would it have potential to damage the ECU?
2) Has anyone with a VDO tach gotten them to work 100%?
3) Do people seem to truly have ZERO issues with the Autometer or Autogauge units? I dont know who made the Summit brand unit I have, but it reacts fast. and is dead nuts on at redline.
Thanks!
