where to get a oil cooler?
see here: https://ls1tech.com/forums/lsx-parts...-deadener.html
This should be the bypass plate. Take that part number to any GM dealer.
GM PART # 12577903
CATEGORY: Engine Oil Pan/Reinforcement
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $8.97
OUR PRICE: $5.32
The new plate does not have the provisions for tapping for a fitting. The boss that stuck out the side is no longer there.
__________________
Just make sure you do not get a trans fluid cooler, it could not take the pressure!
and off topic, but Bo... I'm going to use your write-up @ pirate4x4 to put together an LQ4/4L60e/np241 setup in my '72 Scout II, so you'll be hearing from me a bunch soon.
I have been looking at swapping to a 6l80. But I would have to change alot with the motor.
I would think about using the 4l80 lot stronger.
