Power steering leaking at the gear box
Edit: I drove the car probably 40 miles before it starting leaking the first time, and now I can't even slow the leak down
heres an adapter fitting I think your talking about...the brass insert on the right looks exactly like the end of the factory line with the exception that it is longer then the factory one is. When I tried putting it into the box, 1.25 turns and the fitting was finger tight. The brass piece is also somewhat lose inside the port in the box, but maybe its suppossed to be?
