Anyone using aluminum fuel line?
Thanks for all the replies. The Speedway Motors tubing arrived today, and that's what I'm gonna use since they claim a 250 psi rating.
July of 2007 the engine bay of my 2000 Trans Am burst into flames while working on the car in my attached garage. A fuel line burst because it was rated 5 pounds less than required. I do not want to relive that at all! Therefore, it's worth the extra $40.00 to get something that I know is going to be safer.
im curious in the speedway line thickness also. i just bought 5/8 aluminum summitline because i called them and they said 250psi im going to run it on a carbed blow threw setup
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
#33
Lol,there for lies the reason I hardly ever use sponsors.id just get it ordered up from summit if you found everything.i can't stand on having to wait and rely on someone to get back to me
#34
I know it is super bowl weekend and all, but at the same time I saw both of them online for over an hour and never even got a message saying they would look into it or anything....bout o just hit purchase at summit and get everything I need. Summit is not always the absolute best price, but looking at the sponsor websites vs summit it looks like they are a little better on this one and they always have it to me in like 2 days max.
#35
some of our sponsors are better then others. Id agree on summit being pretty reliable on parts. sometimes a bit over priced, but pretty reliable. You wont gop wrong with the aluminum hardlines either off of summit. If your really worried about it, you can get aluminized steel but aluminum on the return side will definitly get the job done. just make sure the ends or fitted on tightly
#37
3/8" aluminum seamless hardline
-6 tube nut
http://www.summitracing.com/parts/sum-220633-2
-6 sleeve
37 degree flair tool
http://www.summitracing.com/parts/sum-900311/overview/
-6 tube nut
-6 sleeve
#38
-6 tube nut
-6 sleeve
-6 tube nut
-6 sleeve
#40
