th350 trans kickdown with a ls1?
trying to run a th350 with an lq4....trans kickdown linkage...brackets?
thanks
Cruise moves the TB by pulling. The kickdown is pulled by the TB. Compare to throttle cams which used both, ex: TPI. Cruise and TV cable stubs are on opposite sides of the cam. Luckily there are kits to add a stub to LS TBs
Kickdown isnt nearly as important as the TV cable on 700R4's. Its not necessary to run, without it you simply wont automatically downshift when the throttle exceeds the preset downshift amount (Usually 35% for one gear, 70% for two). For a drag car this is a non issue as they never downshift. Streetcars do so the kickdown is optimal
