Carb size opinions
It has a very mild cam so my shift points should not be over 5500, if that.
I ran the numbers on the carb calculator and came up with 580 cfm.
Does a 600 carb seem ridiculously small for this motor or do I just need to realize the math is more accurate than my ego (bigger is better)???
In the mean time try using the search button to view some existing info
https://ls1tech.com/forums/conversio...-database.html
https://ls1tech.com/forums/conversio...-dist-ls1.html
Seems like the most common carb size is a 750 CFM. These motors flow more air than the first gen motors, so different rules apply.
To sum it up, Carbs are rated at 1.5-in Hg pressure drop. At wide open throttle your engine should be between 0 and 1-in Hg. Hope this helps. By the way, as stated previously, a 650 DP or a 750 Vacuum Secondary would work well on that engine in that truck.
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
