New swap oilpan
Old Nov 11, 2009 | 09:43 AM
sparkwirez06's Avatar
Default New swap oilpan
http://cgi.ebay.com/ebaymotors/Cast-...item4a9c278410
Looks like this pan may help out in a lot of swaps!!
Old Nov 11, 2009 | 10:00 AM
71 chevelle's Avatar
I seen that several days back but as far as I have read their has been no actual testing of the pan. Only fitment was tested. I think he is a member here user (retrolsx)
Old Nov 11, 2009 | 11:08 AM
psiconversion's Avatar
LS1Tech Sponsor
Interesting. I am a firm believer in cast pans as opposed to fabb'd pans.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 11, 2009 | 01:06 PM
DGGM WX3's Avatar
This could be very useful.
Old Nov 11, 2009 | 05:56 PM
claytonisbob's Avatar
I wonder how tall the front of the pan is (for tie rod clearance on A-body's)
Old Nov 11, 2009 | 06:35 PM
Bowtie70SS's Avatar
The guy is starting a LS engine swap business. He has posted over at Team Chevelle and his stuff looks good as far as I can tell. http://www.chevelles.com/forums/show...ht=ls1+oil+pan
Old Nov 11, 2009 | 11:26 PM
71 chevy's Avatar
It looks like an lh8 with 1.5 inches chopped off and then smoothed. Nothing wrong with that as my next build will go that route and save me about 300bucks over an autokraft pan
Old Nov 11, 2009 | 11:55 PM
77LS1VETTE's Avatar
http://www.jegs.com/webapp/wcs/store...m=809-19212593
Old Nov 12, 2009 | 01:32 AM
DGGM WX3's Avatar
that's the LH8 pan
Old Nov 12, 2009 | 06:33 PM
NemeSS's Avatar
looks like the pan may work well where the fbod pan is needed
Old Nov 14, 2009 | 09:49 AM
Jimbo1367's Avatar
I just seen that pan on e-bay. kinda pricey IMHO
Old Nov 14, 2009 | 06:38 PM
RetroLSX's Avatar
It’s called the LHX
This oil pan is cast at the same foundry that casts the LS9
It has 2in better ground clearance then a LH8 and has a total depth of 5.5In
5 quart oil capacity not including the filter.
Includes
Oil pan & Oil Pan Baffle
Custom Oil Pick Tube
Drain Plug, Oil Cooler Cover assembly and gasket
The pan uses the OEM LH8 windage tray, OEM LH8 filter and dipstick.
The pan is going to ship in 4-6 weeks times. The Pan has been through all the prototyping and has going into final production and is awaiting the final production run. The first batch is going to be only 50 units, so I’m taking pre-orders on this set up
The pan will clear the A-Body set up and will be the pan used in a new line of lsx swap kits and stainless headers currently in development that are going to be considerably more reasonably priced then what’s currently offered. Test fitting with early cast pans have been started. Some kits will retain OEM pans if possible but ground clearance issues are now a thing of the past in swaps that used the LH8. I will also be a sponsor on this site as of December and will have more technical and pricing upon that time..
Old Nov 14, 2009 | 08:10 PM
reamo04's Avatar
for 400, you can buy a factory LS1 oil pan, pickup, and windage tray....
Old Nov 14, 2009 | 09:25 PM
bczee's Avatar
With the added ground clearence and the having the OEM lower/rear bolt being utilized, this seem to be a pan that is going in the right direction for Swap.
I am about to start my 71 Nova Swap with a LS1.. so I am going to try this pan.. I have already communicates with them on ordering one to be getting one of the 1st 50.
Old Nov 15, 2009 | 07:43 AM
71 chevy's Avatar
I used the champs pan in the nova, no complaints. but going forward I will buy a cheap lh8 for $30-50 and have my welder lob 1.5" off the bottom. he charges 30 for cast alum so thats $60-80 for the pan. it will have the same oil capacity as the lhx pan above at a much lower price point
Old Nov 15, 2009 | 12:16 PM
spacemanspif's Avatar
Where are you getting an LH8 pan for $30-50? If you can get pans that replicate that LHX for far cheaper you should make a bunch and sell them. I know I'd be willing to buy if I could pick of better ground clearance of around the same price as SDCP sells the LH8 for.
Old Nov 16, 2009 | 09:11 AM
RetroLSX's Avatar
The pan offers a smaller rear sump over the F-pan that offers better clearance to swaps. This is not for all swaps, a 2nd or 3rd gen camaro run an OEM ls1 pan without any issues. Yet some other swaps need this for ground clearance and front accessory clearance such as a first gen, A-Body G-body and countless other swaps. There is countless way to do swaps this is just a new option. This pan is priced on par with most aftermarket pans also note that no remote filter is needed and this is cast not stamped sell. As for a modded OEM pan there is a lot of issues when you cut a cast pan. Also note that with a cut pan, the OEM pick up tube would also have to modded as well. The other issue without the smoothing of the pan the OEM lh8 with have far less oil capacity then 5 quarts
Old Nov 16, 2009 | 12:21 PM
NemeSS's Avatar
sounds like it will make for an excellent bolt in type pan, and also have the factory look. and no longer need to chop up used pans. should sell strong.
Old Nov 16, 2009 | 09:59 PM
TURBO BUICK's Avatar
Default New LSX oil pan
Great pan for the "A" & "G" body cars as well as others. I liked it so much that I ordered one for myself. Also Shawn (RetroLSX) is a great guy to deal with.
Rich
Old Nov 16, 2009 | 11:21 PM
Dave-1970's Avatar
Just curious, but what improvements have been made on this pan to clear steering linkage on an A-body? To me it looks too deep in front just like all the other pans that run into clearance issues up front?
