Almost ready 70 chevelle
Old Nov 11, 2009 | 03:20 PM
nicholas1752's Avatar
Default Almost ready 70 chevelle
I am almost ready to start my ls6/t56 swap into my 70 chevelle. I need to round up a few more parts, and clean the garage. Here is what I have so far:
GMPP ls6 with AFR heads lunati cam typhoon intake\
Edelbrock headers with brackets
rebuilt t56
spec flywheel with clutch
GMPP wiring harness/ecm
F-body accessories and brackets
My plans are:
Notch the frame for the oil pan and ac.
Cut the tunnel out and make a new one after the trans is in
Flip the bracket on the crossmember
Everthing else will fall into place (HA HA)
I will post pics asap (probally in a couple of weeks when I begin the swap)
Any input would be greatly appreciated.
Old Nov 11, 2009 | 04:30 PM
Bowtie70SS's Avatar
Working on virtually the same swap right now. Good luck and I am going to subscribe to your thread. You might check out Stealth71 and KST8Engineer as they have successful builds on the street.
https://ls1tech.com/forums/conversio...lba-toast.html
Old Nov 11, 2009 | 05:56 PM
lamdenali's Avatar
I'm doing the same car , collecting part too, am doing a 60L with 4l60e for now and stand alone harness. I'm also subscribe
MillerTime85's Avatar
Old Nov 11, 2009 | 06:39 PM
bczee's Avatar
What mounts and oil pan are you using.. you many not need to Notch for the pan depending on which you use.. If your using the OEM AC compressor, yes you will need to notch there.
Check out the aftermarket pans or the one that BRP/Retrolsx is marketing ($399 right now, can be found on ebay). I got away using a CTS-V pan without notching the x-member for it.
Old Nov 11, 2009 | 09:10 PM
psiconversion's Avatar
LS1Tech Sponsor
GM Hot Rod pan is a good choice at $150. How does the BRP pan compare dimensionally? Anyone know?
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 11, 2009 | 09:32 PM
Default oil pan
I may be a bit nieve but I think the GMPP Ls6 comes with the cts-v oil pan. if so than no notching required. When I get started I will see, but I probally will make what ever I have work to save a little $$. The motor mount adapters that I have are from Edelbrock. I figured if I use their headers than I should use their mount plates. I will say the headers look really nice, but I won't celebrate until I see how they fit. When I had my Gen 5 502 the hooker procomps that cost me 600 fit like crap out of the box. I plan to take lots of pics and try to update as much as possible when I get started.
Old Nov 11, 2009 | 09:35 PM
Default melba toast
Bowtie70SS
love the dazed and confused clip. I checked out your thread also The build looks good.
 Michael S. Palmer
Old Nov 16, 2009 | 07:54 AM
garage almost clean pics soon to follow.
Old Nov 18, 2009 | 10:06 PM
I am a bit slow. How do I insert pics?
Old Nov 18, 2009 | 10:16 PM
JeaneZ28's Avatar
When you post look below and click the link "manage attachments". Then upload the files from you computer. The other way is to load them on photobucket and then paste the link in the message box.
Old Nov 18, 2009 | 10:26 PM
Here is a pic of the engine>
Old Nov 18, 2009 | 10:28 PM
I will take better pics this weekend and post asap.
Old Nov 19, 2009 | 10:38 AM
lamdenali's Avatar
Is that the Professional Product intake ?
Old Nov 20, 2009 | 07:03 AM
Yes, its the 85mm Typhoon.
