LS1/Vortec pcm's and harnesses - what can be used together?
Old 02-28-2010, 10:09 AM
spartanv8's Avatar
LS7's from the new z06
Old 02-28-2010, 07:36 PM
Pocket's Avatar
Good progress. With all the wires labeled with their assigned pin, installing them into the connectors will take very little time. Be sure to double check the circuits with a multimeter before looming
Any reason you've got the intake on backwards? Whats this going into?
Old 02-28-2010, 09:44 PM
spartanv8's Avatar
Thanks Pocket, will be sure to double check for continuity. Whats the best way to bring all the pink ign wires and grounds together? Terminal strip? Big nasty soldered mess?
Intake is turned 180 deg to clear the engine cover and get more room up front, for less wiring going across the motor, and to bring the air intake essentially into the cockpit. This will be going into my spartan v8 roadster, see below =)
Quick Reply: LS1/Vortec pcm's and harnesses - what can be used together?
