oil pressure
Old Nov 22, 2009 | 09:43 PM
hifi875's Avatar
Angry oil pressure
bought a freshend up 5.3 for my 69 camaro. got it in, carbed setup and all. starts first time no prob. NO oil pressure. i ran it for maybe 20 sec. what do i look for, maybe bad oil pump, gear or what. how hard is to replace oil pump?
Old Nov 22, 2009 | 09:55 PM
busta9876's Avatar
What are you using for an oil pressure gauge, electric or mechanical? I would want to verify with a mechanical gauge before determining the issue internal.
Behind the rear engine cover (behind flex plate) there is a small plastic plug that goes into the oil galley. If this was left out during the overhaul, you'd loose oil pressure I belive. There should be a few posts about this if you search for it.
might read this: https://ls1tech.com/forums/generatio...sure-idle.html
Old Nov 23, 2009 | 04:54 AM
LS1MCSS's Avatar
If it's just been apart, there is a good chance they pinched the o-ring that goes on oil pickup tube. It is a common problem with these motors.
Old Nov 23, 2009 | 07:45 AM
rockytopper's Avatar
If it has set long it may just need to be primed. THese lsx engines have to suck oil a long ways to reach the pump.
Old Nov 23, 2009 | 07:55 AM
hifi875's Avatar
tried w mech gauge. i ll check on oil galley plug.. it doesnt have any leaks though. and i ll pull the valve covers to see any other advice is welcome.
thanks
Old Nov 23, 2009 | 02:18 PM
wadd's Avatar
there's a port on the left cylinder bank at the back of the block, down where the "cylinder bore" part of the block case meets the bottom end holding the mains. If you pull that screw in plug, you can look up into the bore to see if the plastic dog bone plug is in place. Will save you pulling the transmission and rear cover to see if it is in place. If it's not there, that's the problem. If it is there, then you move onto the o ring on the pickup.
Old Nov 23, 2009 | 03:37 PM
If this engine has set for any length of time as stated above It may just need to be primed. I pulled my used ls1 engine 3 times and replace the 0-ring 3 times and double bolted the tube and even rtv'd the oring and flange still no pressure. My problem was that the pump would not prime because it was dried out. I primed the pump and instant oil pressure on the gauge. Good luck. I'd prime the pump before I did any thing else might save you some work.
Old Nov 23, 2009 | 03:54 PM
Pop N Wood's Avatar
Remove the spark plugs and crank it over that way until you fix the oil pressure problem. I got good pressure while cranking without the worry of damage from running with no oil.
Old Nov 23, 2009 | 05:04 PM
hifi875's Avatar
how do u prime the pump?
Old Nov 23, 2009 | 05:09 PM
Ackattack1's Avatar
how do you prime the pump on one of these engines?
Hopefully I'll be starting mine this weekend.
Old Nov 23, 2009 | 05:43 PM
hifi875's Avatar
well turns out to be oil pump, upon tearing down everything looks fine except it. now i need a cam. what do i need w/out changing valve springs etc.
Old Nov 24, 2009 | 07:52 AM
There are a couple of ways as I understand it but in my case I simply overfilled the crank case with cheap 5w30 oil (19 quarts) till it ran out the plug on the lower front drivers side of the block. That puts oil in the pump itself. I then spun the engine over with out starting it and had instant pressure on gauge. I then drained the oil out filled to normal level with the good stuff fired the engine and have 11 k on it sense the swap no issues. I have been told some one makes a priming kit but have never seen one personally. Some one else here stated they jack the rear of the car up to achieve the same thing without using as much cheap oil. Sounds reasonable but I have never tried it.
Old Nov 24, 2009 | 07:56 AM
hifi875's Avatar
thxs all
Old Nov 24, 2009 | 07:58 AM
the_merv's Avatar
I always dumped Oil in the Pump and spun it around before I installed it on the Engine..that is a good thing to help it prime up.
Old Nov 24, 2009 | 04:58 PM
Old Geezer's Avatar
Default What..
was wrong w/ the pump??
A new cam without springs is a waste of time...
