t56 crossmember and hooker headers question
ok i got a 67 camaro and im workin on puttin a 5.3 and t56. i got two questions im hoping someone can help me with.
first has anyone tried the hooker headers? i built motor mounts but there not the ones that holley make, i made the ones that the front bottom ls1 mount bolt also goes through the old school sbc mount. i believe s&p make the same ones.
also anyone have an idea of how to modifythe th400 crossmember to fit the t56? or does anyone have any plans or pictures of a custom fabbed one? any help is really appreciated
69 Camaro LS3 transplant.
I believe your motor mounts will need to be a tad bit further forward to keep the hooker headers from hitting the steering petman arm. You won't be able to use the same bottom hole of the sbc mounts into the LS bolt hole on block. Your mounts will need to be about 1" further forward, hence the Carshop Moutns = 1" setback.
You can also check out a Crossmember I fabbed from a kit for $50 bucks.
hooker mounts
![](https://i34.photobucket.com/albums/d124/LuvNStarGazn/camaro/100_5655.jpg)
s&p (carshop mounts)
![](https://i127.photobucket.com/albums/p151/justingiese/harness.jpg)
the hooker mounts move the engine right against the firewall. the s&p style mounts move it an inch from the firewall.
i am running a t56 crossmember form ATS along with my hooker headers. lots of room. also, my hookers needed to be dented and i also took a little metal off my pitman arm. the headers are designed to clear the steering box by setting the engine back.
thanks alot i got my hooker headers in today looks like if i put a small ding in them they will clear the steering box and the pitman arm was fine but im thinkin maybe on going rack and pinion. does anyone have this? does it make it steer like a newer car?
