removing wiring for electronic transmission
Old Nov 26, 2009 | 01:30 PM
kornerz's Avatar
Default removing wiring for electronic transmission
i cant find anything on what wiring i need to remove on my 2002 5.3 harness since im going with a th350. Im in the middle of pulling all the rest of the wires off but im not sure what to do about the 4l60e connections. Any help would be great.
Old Nov 26, 2009 | 05:48 PM
Pocket's Avatar
You must retain the VSS wiring if you stay EFI. Either swap the tailhousing for a large VSS style or get one off a non-cable 700R4. If neither option is available, use a differential mounted reluctor from jagsthtrun
If this is in a 4th gen or pretty much any GM car with ABS, use a wheel sensor and ignore the above. The down side is ABS will no longer function
Old Nov 26, 2009 | 10:42 PM
kornerz's Avatar
ive been thinking about this all day, i might just stick with a 4l60e. I plan on driving the car on the freeway alot and i dont want the motor screaming at 75mph.
Old Nov 27, 2009 | 09:38 AM
Pocket's Avatar
No real benefit to removing the pins even if you plan on keeping the TH350 permanent
Just leave the connector loose
Old Nov 27, 2009 | 11:48 AM
psiconversion's Avatar
LS1Tech Sponsor
I agree with Pocket. Put the connector in a zip lock bag and tie it up out of the way. Also, I would leave the 4L60E. Why not take advantage of overdrive.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 27, 2009 | 02:03 PM
kornerz's Avatar
yeah, im sticking with a 4l60e for sure now. Thanks for the help guys.
