what to do with the rest of the c2 wires
So i worked my 02 truck harness yesterday and im pretty much done with it just not sure what to do with the rest of the wires off of connector c2. Im not using the stock fuse box, i had one off a 94 z28 im using. I know im using all the pink, orange, grounds and the green with the white stripe. What do i do with tha rest of them? the harness is going in a 92 fox with a 4l60eThey are:
LT GRN 24 Backup Lamp Supply Voltage
LT BLU 1320 CHMSL Supply Voltage
PPL 6 Starter Solenoid Crank Voltage
LT GRN/BLK 584 A/T Shift Lock Control Switch Supply Voltage
LT GRN 275 Park Neutral Position Switch Park Signal
YEL 1737 Neutral Safety Switch Park/Neutral Signal (Automatic Transmission)
as always, thanks
as always, thanks
sorry about that, here are the pin numbers
A3 DK BLU 604 A/C High Pressure Recirculation Switch Signal
A9 LT GRN 24 Backup Lamp Supply Voltage
A10 LT BLU 1320 CHMSL Supply Voltage
B3 DK GRN 59 A/C Compressor Clutch Supply Voltage
B5 LT BLU 203 A/C Request Signal
D3 DK GRN/WHT 459 A/C Clutch Relay Control
D11 PPL 6 Starter Solenoid Crank Voltage
E3 LT GRN 275 Park Neutral Position Switch Park Signal
F3 LT GRN/BLK 584 A/T Shift Lock Control Switch Supply Voltage
F10 PPL/WHT 1035 Starter Relay Coil Supply Voltage
F11 YEL 1737 Neutral Safety Switch Park/Neutral Signal (Automatic Transmission)
02 harness will have 2 80 pin connectors. Blue connect is C1, red C2. The pins are labeled 1-80
The A-F row and numeric pin assignment sounds like a much newer than 02 harness
In the mean time, read this
http://www.lt1swap.com/99-02_vortec_pcm.htm
