4.8l fleplate problems please help!
I recently bought a 2000 1500 silverado with the 4.8l with a manual transmission, the manual tranny is going and is being replaced with a 4l60E the problem im having is this motor seems to have the wide crank flange and the standard dished flexplate will not work
what do i need? can i use a 6.0 flat flexplate from a 99? anything else i should be aware?thanks in advance
Any flat 6.0l flex plate will work and you won't need the spacer as well.
You will need the earlier 4l60e converter (1997-1999) Gen I or a 4.3L converter.
