which way does the water flow from the pump?
Old Dec 2, 2009 | 12:01 AM
ssduane's Avatar
Default which way does the water flow from the pump?
Doing my VA A/C install and need to hook up my water lines to the heater coils and the heater valve needs to go on the discharge line, is the front or rear water pump port the discharge line?
Thanks guys.
Old Dec 2, 2009 | 05:36 AM
Pop N Wood's Avatar
The larger fitting is the supply line.
My bad, looks like I had it backwards
Old Dec 2, 2009 | 05:55 AM
rao's Avatar
rao
Actually I believe it is the reverse - the smaller fitting to the rear is the outlet from the pump and the larger fitting to the front is the return to the pump.
Old Dec 2, 2009 | 10:30 AM
Andy1's Avatar
The smaller fitting is the hot side (to heater), and the larger fitting is the return side.
Andys
Old Dec 2, 2009 | 11:02 AM
bczee's Avatar
Like most system, (AC, power steering, Radiator, etc).. The Heater core is no different, the smaller line is the pressure or feed.. the larger is usually the return line. Remebering this is always a good general rule to use.
Old Dec 2, 2009 | 12:27 PM
ssduane's Avatar
Thanks all!
