95 Camaro LT1 to LS1 Swap info?
I can get a 95 Z28 from the dealership i work at for $1800. Whats all involved with swapping it over to the LS1? I figure id get a full LS1 Motorset with ecu, wiring, and whatever else i can get with it. Also im pretty sure you gotta swap the K Member too. Anymore info would be greatly appreciated.
ls1 kmember with frame stands and engine mounts, ls1 rack and pinion. you can keep the radiator and fans. i am doing this now with a 97 firebird that had a v-6 in it. the wiring is a pain to me for now getting merv to help me sort thru it. you can buy a stand alone harness from vendors on here or send them a ls1 harness and they can fix it for you if you have the money. i am building mine for the 275 radial class, so i am doing the walbro fuel pump, fuel lines with the corvette filter with return.
Check out my thread. Should have everything you need to know. If not just ask. https://ls1tech.com/forums/conversio...-2000-ls1.html
Not sure you could get one for $1800 though. If the body is good, 1800 is a good deal. Could sell the LT1 in the car for $1000 easy to offset the cost.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
