Wiring harness for 6sp vs auto
Old Dec 3, 2009 | 11:21 AM
FoFittyFoSS's Avatar
Default Wiring harness for 6sp vs auto
Have a 98 harness for an automatic car. Havent purchased the ECM yet. Can I run a 6 speed with the auto harness and does the ECM have to be from a manual car? Another question is, Im looking to convert a LT1 t56 to a LS1 t56 by changing the bellhousing and input shaft. Is the wiring going to be the same? Appreciate any help I can get.
Old Dec 3, 2009 | 11:25 AM
bjamick's Avatar
Yes you can make an auto run a t56. You just have to run a few wires off the neutral safety switch.
Old Dec 4, 2009 | 09:34 AM
Pocket's Avatar
The PCM can be retuned to whatever loadout you're running. Trans type is changed by a few wire and connector swaps
Since you have a 98, it has a specific pinout for that year. Now would be a great time to repin it to +99 style
Old Dec 4, 2009 | 11:33 AM
psiconversion's Avatar
LS1Tech Sponsor
I agree with Pocket. Go to a 99-02 PCM.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Dec 4, 2009 | 03:44 PM
The engine is a 98 as well. What all would need to be changed on it?
Old Dec 4, 2009 | 06:30 PM
Pocket's Avatar
Nothing, the old PCM controls the same things with the same connectors as the newer PCM
Changes begin when you go to GEN IV engines on GEN III controls or vise versus. The only exception is iron truck blocks require a hole to be drilled/tapped for most non truck ALT brackets
