needed : low mount alternator mount 6.0 ls
Old Dec 7, 2009 | 08:41 PM
Dickie-311's Avatar
Default needed : low mount alternator mount 6.0 ls
i'm looking for a driver side lower alternator mount for my 6.0 . the ones i found ..my block doesnt have the holes for it.
Old Dec 7, 2009 | 09:01 PM
blk96406's Avatar
Here ya go, check out this link........
https://ls1tech.com/forums/conversio...ets-6-0-a.html
Old Dec 7, 2009 | 09:13 PM
Dickie-311's Avatar
this is kinda what i'm looking for ..but my block doesnt have the mounting holes
http://www.bmrfabrication.com/misc/AB001_inst2.jpg
Old Dec 8, 2009 | 10:40 AM
blk96406's Avatar
What block are you using???? This is how I did my LQ4.
Old Dec 8, 2009 | 11:33 AM
Dickie-311's Avatar
6.0 lq4 .. the link you posted , that set up would work if i was using the factory wp and tensioners ... my motors only going to have a alternator hanging off it .
Old Dec 8, 2009 | 11:54 AM
E-Works's Avatar
im confused. this is how we did our ls2 . same bracket as in the pic with the mezeire water pump. u saying the lq4 iron block doesnt have the hole tapped in the block where the ls2 block does? can u tap the hole?
Old Dec 8, 2009 | 12:20 PM
blk96406's Avatar
I used the lower hole that was already in the block. Used a fbody alt mount/alt, actually used the mount as a template, marked my hole just like the picture in that link. I drilled and tapped it in the car even....... Make sure you use that little bracket that mounts to the back of the alt and to the block, just under the head, and your good to go.......... If all your running is an alt, check this link out......
http://www.bmrfabrication.com/misc.HTM
Scroll down and look at their alt mount. This is what I was originally gonna do, but decided to keep the stock water pump. Look at the pic on the left (in the link), your block has that hole already. The one up on by the head is the one you have to drill/tap on yours. The other one closest to the "front cover" is the one you dont use..... as long as you use that little bracket on the back side of the alt.
Hope this helps you out............
Old Dec 8, 2009 | 12:40 PM
techrunner's Avatar
can you use the small bracket off the back on the lq4 alternator though? i got the 145 amp alt for the truck, but i didn't think there was a provision for the extra little bracket on the back.
Old Dec 8, 2009 | 01:08 PM
blk96406's Avatar
I used the stock alt/alt bracket off of a fbody. I dont have a truck alt laying here to look at. The hole for the little back bracket is part of the alt housing. Here is a link to the bracket so you can see what Im talking about......
http://www.nookandtranny.com/mm5/mer...Category_Code=
Old Dec 9, 2009 | 12:04 PM
techrunner's Avatar
yeah, i have the bracket, but i am pretty sure i couldn't find a place to bolt i tto on the back of the truck alt. maybe i should have gone with the f-body alt, but i wanted the extra output. of course now i hear that peopel have had issues with the steering link using the truck alt, so i may be forced to rethink that one.
Old Dec 9, 2009 | 12:08 PM
blk96406's Avatar
Check the classifieds on here, there was a guy selling a fbody alt and bracket pretty reasonable late last week.............. otherwise Im sure you could pick one up from Nook-n-Tranny. Good luck-
Old Dec 9, 2009 | 01:06 PM
Dickie-311's Avatar
so do you need a F-BODY alt to run the set up you have ? .. going to buy and alternator soon .. wanna to buy the right one.
