Trailblazer - 58x or 24x?
Old Dec 10, 2009 | 10:53 PM
waynehartwig's Avatar
Default Trailblazer - 58x or 24x?
2006 Trailblazer SS with the LS2.
Anyway to tell by just looking at the engine without tearing it apart and counting teeth?
I need to know which it is so I know if I need an E40 or E38 PCM.
Thanks!
Old Dec 10, 2009 | 11:00 PM
ls1nova71's Avatar
Look at the crank sensor behind the starter, grey=58, black=24.
Old Dec 11, 2009 | 11:24 AM
built408's Avatar
They switched to the 58x halfway thru 2006 in the trailblazers. So it could be either. Like stated above, look at the crank sensor.
Old Dec 13, 2009 | 01:36 PM
Thanks guys! I thought it was that easy, to look at the sensor, but I couldn't remember the details or if it was possible.
So if it's the 58x, can I throw a E38 PCM at it or does it go to the E67 then? Or is that all dependent on if it has VVT or not?
Old Dec 13, 2009 | 08:30 PM
Bo185's Avatar
Wayne
Originally it had the E40 on both 24x and 58x ones. The E38 should work with it if its the 58x,then tune out the VVT if the ECM had it.
Old Dec 14, 2009 | 09:20 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
A few points:
The 06 TBSS is a 24X engine with the E40 ECM.
The 07 and up TBSS is a 58x engine with an E67 ECM.
The 58X version can be run with either an E67 or an E38 (if doing an engine swap).
The 24X version runs with the E40 (or an older LS1 PCM if doing a swap).
ALL 2006 TBSS are 24X with E40.
The E40 will not run a 58X engine.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
