Couple of errors and no tach
Old Dec 13, 2009 | 09:13 PM
Ackattack1's Avatar
Default Couple of errors and no tach
My Autometer Sport Comp tach is not working. It's reading 0
I'm using an 05 truck ECM and I'm getting the following codes
PCM] P0650 - Malfunction Indicator Lamp (MIL) Control Circuit
[PCM] P0654 - Engine RPM Output Circuit Malfunction (Pending)
Old Dec 13, 2009 | 11:36 PM
Ackattack1's Avatar
I got te P0650 cleared up, but still no tach function.
Old Dec 14, 2009 | 12:11 AM
busta9876's Avatar
this will get you going...tach should be set on 4 cylinder to read correct, unless programming was done in the PCM to change that.
, I know this has been covered many times...
Old Dec 14, 2009 | 07:08 AM
Ackattack1's Avatar
yeah, I've seen that, but nobody mentioned the error code
stopping by radio shack tonight
Old Dec 20, 2009 | 05:58 PM
iansane's Avatar
If my stock tach is an 8 cylinder setup can I half the resistence (340ohm) and get the correct output on my tach or am I hoping too much that something like that would work?
Old Dec 20, 2009 | 10:51 PM
Ackattack1's Avatar
No
you need to change the tach output in the tune
Old Dec 20, 2009 | 10:58 PM
iansane's Avatar
Yeah, figured. Wishful thinking. I have no way of changing that.
Old Dec 21, 2009 | 04:54 AM
LS1MCSS's Avatar
Dakota Digital makes a small tach interface box that will change the signal, if you don't want to have it changed with a tune.
Old Dec 21, 2009 | 10:33 AM
gofastwclass's Avatar
SGI-8 is what you need. It's pretty simple to hook up, works well and the instructions are excellent. Did I mention the whole thing is slightly larger than a cell phone?
