LS1 240sx with a problem - please help!
Old Dec 15, 2009 | 01:57 PM
ramblin240's Avatar
Default LS1 240sx with a problem - please help!
I have a 98 240sx with a 2002 Camaro LS1 + cam + dual valve springs and many other suspension and handling goodies.
Problem is, the car, when cranked up, sounds like there is severe scraping/knocking (no codes thrown) that is matched with the rpm even at idle. This just started yesterday and i have had what i believe is a very small coolant leak that I have yet to diagnose...I have checked:
- o2 sensors
- MAF
- Fuel Filter
- Air Filter
- Oil pump (oil getting to the top of the heads)
- Plugs
One thing i have yet to try is fuel pressure bc I dont have a gauge, but I will get one soon.
Anyone have any ideas? Thanks in advance!
Old Dec 15, 2009 | 02:02 PM
00transamnh's Avatar
Are you sure the tune is where its supposed to be?
Old Dec 15, 2009 | 02:03 PM
ramblin240's Avatar
The tune has been good for 2+ years now so Im pretty sure. I drove it to work, it was fine, then I turned it on to go somewhere and I got this sound...
Old Dec 15, 2009 | 02:05 PM
silverz28camaro's Avatar
did you check the rocker arms? make sure none are loose. maybe take a short video to and post it up to see if the noise is coming from the top end. maybe also check the flywheel torque converter/ or clutch bolts are all tight.
Old Dec 15, 2009 | 02:07 PM
ramblin240's Avatar
I checked that they were covered in oil as they should be in case my oil pump was goin out. Could it be the pushrods? The sound still remains when I put the clutch in.
Old Dec 15, 2009 | 02:16 PM
did you just look at the rockers or did you try to feel them by hand to make sure none cam lose of the needle bearings didn't go bad.
its going to be hard to help you pinpoint this without hearing the noise clearly.
Old Dec 15, 2009 | 02:29 PM
ramblin240's Avatar
Video comin soon.....
Old Dec 15, 2009 | 04:05 PM
bovi's Avatar
Strange, lets see vid.
Old Dec 15, 2009 | 05:20 PM
ramblin240's Avatar
http://www.youtube.com/watch?v=X6yiJL1ztdk
wfs
That is the car running. Please listen to the crazy sound. I really think its a vacuum leak.
Old Dec 15, 2009 | 08:21 PM
ramblin240's Avatar
Fuel Pressure at 70 psi.
Im beginning to think my leak is in my brake booster b/c my brake fluid is unusually low and this seems like it could be a likely culprit given the age of the car.
Ideas?
Old Dec 16, 2009 | 12:12 AM
sounds like valve train to me but its still hard to tell by the video. I'd cheacl all rockers at top dead center, one cylinder at a time.
Old Dec 16, 2009 | 11:45 AM
SikkyMFG's Avatar
Sounds like a bad lifter, have heard this before. Very high pitch so that would put the source of the noise in the valve train and not rod or wrist pin.
Old Dec 16, 2009 | 12:45 PM
ramblin240's Avatar
I had thought about that too...man, there are so many things it could be! crap..
Old Dec 16, 2009 | 12:49 PM
ramblin240's Avatar
Gonna take off belts today and see how it runs for a few seconds...maybe its an accessory...
Old Dec 16, 2009 | 01:07 PM
bovi's Avatar
Its always a pain in the *** to find something like this, but i'd say like sikky.
Old Dec 16, 2009 | 02:43 PM
ramblin240's Avatar
Takin the belt off didnt help.....
Old Dec 16, 2009 | 03:34 PM
ramblin240's Avatar
What about worn out lifters? Did anyone watch the video and think anything from it?
Old Dec 17, 2009 | 08:24 AM
SikkyMFG's Avatar
listened again, I would put money on a collapsed lifter. Great opportunity to upgrade the valve train and install a new lifter set. Just my 2 cents.
Old Dec 17, 2009 | 09:35 AM
ramblin240's Avatar
So here's my next couple steps:
- Check oil pressure
- Pull lifters (any way to know they are bad other than diagnostically? test of some sort?)
Any more ideas?
Old Dec 17, 2009 | 10:47 AM
TT632's Avatar
X2. If the wheel is siezing up it will have a screaching noise that is fairly continuious. check it out before you cause more damage
