82 Corvette LS1 T-56 Swap Build Thread
Old 02-13-2010, 11:49 AM
  #41
bonecrrusher's Avatar
NC got hammered with snow this week, link on DC looks good!
Old 02-14-2010, 03:48 PM
  #42
82cetuner's Avatar
yup I am actually in NC for leave right now I got a good shot of the vette under 6 inches of snow. atleast it was the kind of snow I like the dry kind that only hangs around a day or two.
Old 02-15-2010, 02:46 PM
  #43
the.erinyes's Avatar
Default 4.11 Gears
How are those 4.11 gears working out? Some guy's running with 4.08 find first gear basically useless and second not much better. I would be interested to hear about your experience.
Old 02-15-2010, 06:22 PM
  #44
82cetuner's Avatar
1st gear is fairly usless for daily driving, but for your get up and go its amazing if you keep your traction. with the 4.11s it makes the gear ratios very tight you can keep it in 4th pretty much all the time even when slowing down to 10 mph or less to make turns I like them, I definetly would not go HIGHER but backing down a gear would still keep me happy.
with the t-56 and 4.11s it makes for a great combo.
rpms are still very resonable at interstate speeds
Old 02-16-2010, 07:38 AM
  #45
Default 4.11 Gears
Thanks for the update. I think I am going to go with 3.55s to try and make a more civilized daily driver. I think stock runs around 3.42 or less.
Old 02-16-2010, 02:16 PM
  #46
kilrcady's Avatar
is only me or does digitalcorvette.com have a really sloooowww server?
Old 08-10-2014, 10:27 PM
  #47
Patro46's Avatar
Correct me if I'm wrong, but doesn't the heater hose return your mechanic modded totally bypass the thermostat on it's return from the heater core? And isn't it the heater hose return responsible for proper thermostat operation?
Originally Posted by 82cetuner
Now its time to drop the motor back in and start puttin all the goodies on.
SITTIN PRETTY!!!!!!!
Old 05-24-2018, 12:07 PM
  #48
snipescastle2's Avatar
Default Earlier Vette differential mounting
hi! Nice build! When you replaced the center section,
did have to change the “Aluminum back brace/mount”? Or did you have to fab new half shafts/ mounts? Just curious as to wether you used the ‘82 pieces in addition to the cast iron center section.
thanks!
Ben Smith
Quick Reply: 82 Corvette LS1 T-56 Swap Build Thread
