Calling all 67 chevelle Guru
Old Jan 1, 2010 | 09:43 PM
lamdenali's Avatar
Default Calling all 67 chevelle Guru
Am having trouble looking for a company that make crossmember for the 4L60E tranny crossmember. Can someone chime in with this ?
Old Jan 2, 2010 | 05:56 PM
Bowtie70SS's Avatar
You can use the stock crossmember. You don't want the rear of the trans any lower than it sits on the stock crossmember or you might have pinion angle (vibration) problems.
Old Jan 2, 2010 | 06:56 PM
kevin 67/6.0's Avatar
i used stock cross member with no problems or mods you just have to find the trans mont
Old Jan 4, 2010 | 10:08 AM
lamdenali's Avatar
My stock crossmember is too short. Do I have to cut the tab off and mod up a new tab to make it fit ? Kevin do you have any pics on your crossmember ?
Old Jan 4, 2010 | 06:26 PM
Bowtie70SS's Avatar
You mean it sits too far back? You can bolt the crossmember to the transmission mount and drill new holes in the frame. You may only have to drill one.
Old Jan 4, 2010 | 06:49 PM
yes i hade to move it forward and drill one new hole on each side. the back hole moves to front hole
Old Jan 5, 2010 | 10:54 AM
lamdenali's Avatar
Now I understand how you guy did it . I cut my tab off to try and get it to work ,but now I lost the tab some where in my Garage.
Old Jan 5, 2010 | 06:51 PM
Bowtie70SS's Avatar
Oh sounds like you need to find a good used crossmember. Are you a member of Team Chevelle? www.chevelles.com
Old Jan 6, 2010 | 05:15 PM
lamdenali's Avatar
I still have mine crossmember . Just the tab that connect to the tranny mount that I cut off and sant seem to find it anywhere. Yes am an chevelle member
Old Jan 6, 2010 | 06:28 PM
RYU's Avatar
RYU
If you're using the stock crossmember i'm assuming you already did tunnel mods? I used my stock crossmember but definitely had to do tunnel mods.
Old Jan 6, 2010 | 08:14 PM
i didnt have to do any tunnel mods.
Old Jan 7, 2010 | 12:07 PM
lamdenali's Avatar
Mine snug preety tight up there in the tunnel
Old Jan 7, 2010 | 01:30 PM
RYU's Avatar
RYU
in terms of tunnel it depends how far back into the firewall you set the engine. you're bringing up fun memories of when i was trying to balance the tolerances between the firewall, steering box, crossmember, pinion angle, and trans tunnel.
fun times... NOT!
Old Jan 7, 2010 | 02:53 PM
lamdenali's Avatar
It was fun only till I run out of percocet
yes my engine sets to the front a little ferther than i like but it worked with out any cutting
Old Jan 8, 2010 | 11:17 AM
lamdenali's Avatar
I use S & P mod F body pan and it cant go any further. It's only 1/8 off the crossmember.
