Fuel Shutoff in accident?
I'd think that it would need an inertia switch to sense g forces. Any input here?
In an auto... ya... an inertia switch would be the best thing.
http://www.smartracingproducts.com/p...uelshutoff.pdf
http://www.pegasusautoracing.com/pro...s.asp?RecID=87
I've cut 1.34 60' times in my Mustang without the intertia switch tripping (I think that is about 2 G's avg accel), and in my younger days jumped a $300 Ford Escort over several railroad tracks without tripping it. (long enough air time to look at passenger and say WTF) So the trigger happy switches seem to just be random to me and isolated cases.
In moderating this section and working on cars in general for 18ish years, I've seen some rubber line and hoseclamped EFI "fuel systems" that I wouldn't trust on a tractor. Anytime someone engineers their own fuel system it does not meet safety standards anymore unless left OEM. There are a ton of things that can go wrong in a crash, injectors can be pulled from the fuel rail spraying fuel over the engine, pressurised or return fuel lines pulled off or cut over guard rails, brush, etc. It would take a few seconds to kill the engine as the fuel system depressurizes while the fuel pump is still running, and even then the ECM does not power it down instantly. This is all worst case thinking of course but all possible.
I think some sort of crash detection fuel disabling device is a good idea even if it is troublesome, further... some guys don't let the ECM control the fuel pump for whatever reason. I'm not singling you out or anything, just discussing. Remember, I grew up in NE PA.
This thread has me wanting to research retrofitting intertia switches more and more.
I put mine in for cheap insurance, I don't think it made anything too complicated, it's only two wires inline to the pump, and if I have to leave the car somewhere (ie- motel parking lots in towns I'm not familiar with, you never know if your in a "good" part of town or not) I'll hit the switch to make the car just a little bit harder to steal. True that the Ford switch can be overly sensitive, but perhaps Joseph's explanation of trigger happy switches can be remedied with a replacement. A friend had a T'bird SC that got bumped in a parking lot and it failed to start afterward; it likely had one of those trigger happy switches. I think on that car it was mounted in the trunk; my Explorer has one mounted under the dash on the passenger side (it's never tripped in the past 12 years).
Andy1
Andy1
Fuel pump run on after a wreck is the very same reason NASCAR won't allow electric fuel pumps on the cars.
I like that the later switches have provision for a light that signals when it's been tripped.
Andy1
Andy1
BTW, you forgot HOPING it is good since most people can't field test the unit accurately.
http://www.fordmuscle.com/forums/all...ia-switch.html
Apparently the NO contact closes once the switch is tripped, and becomes
+12V in order to power an indicator light untill the switch is reset.
I guess you could field test it by smacking it with a rubber mallet (but not too hard :-)). That Ford site metions 10G's to trip it.
Andy1
Andy1
BTW, your link didn't work.
