ls7 on F-body
Im thinking to install ls7 and t-56 on my f_body 99 ....
What i need to complete this project?
Is t-56 directly will fit the engine?
and please i need wiring data for ls7 computer
best regards
Next question is if you are running it Dry Sump or Wet Sump?
Me personally if I was going to use a LS7 I would re-build it with my current Crank so I can run it with my '02 PCM in my Camaro, and I would have it setup for the standard Wet Sump..which is simple, just a little machine work needed to drill out the Oil Dip Stick Boss.
