HELP from any stang swappers
Old Feb 24, 2007 | 11:38 PM
tirefryin_s10's Avatar
Default HELP from any stang swappers
Im in the process of buildign a turbo 5.3 powered notch stang.....my question is how low does the car pan hang? is there room for the truck pan...i dont mind it being a little bit low but just need to know if its do-able ,the truck pan I already have and already have a return oil line fitting in it etc...... next question is did most of you retain the ford starter solenoid on the fender?
Old Feb 25, 2007 | 01:24 AM
BLWN1's Avatar
curious as well, there was a 5.3 carbd car on ebay, I think it was relisted, and he said he used the truck pan....
Old Feb 25, 2007 | 10:23 AM
BLWN1's Avatar
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Feb 25, 2007 | 05:19 PM
where does it say he used a truck pan??? or can anyone thats done the swap say if its useable or not?
Old Feb 25, 2007 | 09:41 PM
BLWN1's Avatar
I emailed him and asked...
Old Feb 25, 2007 | 11:40 PM
did he say what kinda ground clearance etc he had running the truck pan? thx for checking into it man helps the DIY guys like me out alot
Old Feb 25, 2007 | 11:43 PM
BLWN1's Avatar
He was kinda short, email and ask him for clearance pics... and what pan he used? Said he is working on some swap parts I believe.... I have a 6.0, and a 99 stang found. Pricing 6 spd parts and seeing what all I need, so budget is all me....
Old Feb 25, 2007 | 11:46 PM
hmmmm .... so looks like i can probably get away with running the truck pan i take it then.....
Old Feb 28, 2007 | 03:52 AM
so next question .... has anyone used the stock gauges?? whats needed etc , I will be running auto meter 2 1/6 gauges for all the vitals but would be nice if the stock gauges still functioned .....?
Old Feb 28, 2007 | 02:39 PM
Bueler................bueler...................... .bueler
Old Feb 28, 2007 | 10:17 PM
powershiftkung's Avatar
Truck pan will not work. You will need a Camaro F car pan and even so, you'll need a tubular K for the clearance. Also, the steering rack may need to be lowered with offset rack bushings. I have whole thread on the swap.
Old Feb 28, 2007 | 10:20 PM
BLWN1's Avatar
So you tried a truck pan?
Old Feb 28, 2007 | 10:50 PM
many have used stock k members so i find your view slightly biased..... i would like to see someone try a stock pan in a stock k member (i will most likley go tubular anyways) but i want to know if its do able so i guess i will just have to try it
Old Feb 28, 2007 | 11:15 PM
vanilla89's Avatar
dude,the stock k-member wont work...
show me one the has the stock k-member??
Old Mar 1, 2007 | 03:15 PM
this car runs a stock k member its hard to see in the pics but i know on turbomustangs he said it has a stock k member
https://ls1tech.com/forums/conversions-swaps/532570-ls1-coupe-t-76-a.html
I know its possible ...but most of you think its not so lets move onto the next topic, has anyone succesfully retained any of the stock gauges by using the ford senders in the ls motor?
Old Mar 1, 2007 | 04:41 PM
vanilla89's Avatar
https://ls1tech.com/forums/showthread.php?t=532570
where does it say he has a stock k-member???
a stock,unmodified k-member with a f-body oil pan wont work...
ur as bad a PRAYHRD thinking you know everything about a ls1 mustang when nether one of you have built one
Old Mar 1, 2007 | 06:13 PM
BLWN1's Avatar
Ouch....
Old Mar 1, 2007 | 07:01 PM
alright *** hole then your welcome to leave i didnt say a stock (un modified) factory k would work with a stock un modified f body pan now did i........ and if you know how to read i said in the previous post with the link that it doesnt say in that thread but it does say on turbo mustangs he is running a factory k member .... is it modified ? i have no idea but anything is possible with some work..i might not know alot about swapping an ls in a stang but ive done my share of conversions
76 camaro -factory 6 popper sbc swap
81 chev shortbox factory sbc conveterted to bbc
89 chev s-10 rcsb v8 swap
89s10 rclb v8 swap(also built mounts,roll cage,ford 8 " cowl hood etc etc etc)
81 mazda rx7 sbc swapped
88 s10 blazer sbc/th400 swapped
and my most recent 86 mazda rx7 sbc/200r4 swapped ran 11.27 @ 2800 ft
im by far an expert on anything but thats why i was ASKING a question you dont have to get all bent out of shape just because you cant make something work doesnt mean others cant . As ive stated before i can figure this one out myself as it seems most opt to go tubular......so NEXT QUESTION has anyone succesfully used any of the stock stang gauges
Old Mar 1, 2007 | 07:11 PM
sorry the previous post might have been a bit harsh but just think about it just because you say it doesnt work doesnt mean that its not possible................ here is the quote from Turbo mustangs .. i would post the link but not sure that im allowed
" I USED STOCK K-MEMEMBER. ONLY THING I HAD TO DO WAS CUT OUT JUST A LITTLE BIT TO CLEAR THE OIL PAN,IT WASNT ENOUGH TO HURT ANYTHING. U SHOULD BE OK DOING THAT ."
Old Mar 1, 2007 | 09:40 PM
PRAY HRD's Avatar
i really don't think that was necessary! where do you come off bringing me into this when i've never come across as a know it all?!?!?! hell, i'm the first to admit to everyone who pm's me with questions that i didn't build the car, but i have never acted like a know it all! find me one post where i disagree wtih anyone who's said something, as you have here. show me 1 time that i came across as a dick like you have here. i'll tell you now that you can't! you can go though every last post i've EVER made and you wont find anything. but i do have the capability to repeat what i know and have the courtesy to try to help out someone on here if i can! so the next time you have something stupid to say, keep your fingers off the keyboard!
