LS1 race parts and conversion parts Hewitt/Waco Tx
Almost all these parts are off my nova,they are all in execellent used condition,Just dyno time and a few passes at prairie hill.
Meziere electric race pump 300.00 Pending
TCI flexplate for turbo or glide swap with bolts and pilot 185.00
F body oil pan pick up windage tray gasket and all bolts 225.00 sold
CC XEr cam 281/285 232/236 595/601 225.00
Diamond pistons stock rods and ARP bolts,rings.Needs one piston and rod.The one piston has damage where something got on top of it,it comes with the set but i would not use it.3.905 bore 3.622 stroke 6.098 rod lingth .945 comp height 2.500 pin.325.00
stock crank needs nothing 100.00
front cover 20.00
rear cover 20.00
top cover 20.00
knock sensors and wire harness 45.00
crank sensor cam sensor 30.00 sold
balancer and bolt 20.00 sold
2000 vett intake No egr port 50.00
fuel rail 40.00 sold
8 vett injectors 80.00
Swap motor mts block side 50.00
Auto Rad and fan asy 140.00
Aeromotive A 1000 # 10 fittings 250.00 sold
10 micron filter #10 fittings 50.00 sold
100 micron filter #10 fittings 50.00 sold
# 10 hoses and fittings 50.00 sold
BMR alt relocation bracket 70.00
1.76 low glide Tim built it, has TCI internals TCI 5000 stall,Hipster pro brake,B&M cooler with fan, braded cooler lines, trans temp sender, B&M shifter, B&M **** with button, Electric shift selonid and bracket for shifter W/ cable,no spill dip stick tube Ultra Bell bellhousing.All of this is in perfect condition,I am just not going to drag race any more.It has 4 real passes on all of this.1750.00
Pacesetter LT headers for F body I had them on my nova I did cut the EGR tubes off them and the left one I cut the colector shorter to fit the nova they are coated and do have some dents in a tube to make them clear a TCI front clip.125.00
Synergy studder box 175.00
Biondo Mega 400 digital delay box 175.00
2001 6.0 truck intake less TB with rails and injectors 50.00
Valve covers center bolt 50.00
8 car Coil packs brackets and harness with plug wires 175.00 sold
Aluminum overflow catch can with drain 20.00
LS1 Stand alone wire harness ,fuse box with enough harness to put processor in car under the dash,uncut in perfect condition just a few wires to hook up and it runs.400.00 sold
LS1 stock rockers and bolts used 40.00
lifters and trays used 40.00
oil pump used 20.00
T chain and gear used 20.00
1963 Nova SS Just a old race car body but has TCI front coil over clip with rack and pinion, Rear TCI clip 4 bar and track bar with coilovers.1957 olds Old school rearend 4.88 gears, spool and disc brakes all braded lines and fittings line lock,Wilwood pedals and master cyls,Kirkey alunimum seat belts 15 inch steering wheel and disconect old 6 point chage ,trans crossmember driveshaft,I have been sanding on it I was going to paint it. like all old cars it needs some body work.29.5 10.5 15 MT slicks 10 inch weld draglights 15 3.5 fronts and hoosers tires.Has tach and some gauges in it also.No title bill of sale only,I did check the VIN through DOT and it came back clean,has not been registered in over 35 years,just an old race car.I ran 10.32 and 145 mph with this car.4000.00
I sell on ebay my user name is mddndps I have over 900 + 100% feedback,all parts may be viewed come by and check them out.Thanks Mark D. Mddevo@aol.com
front cover 20.00
rear cover 20.00
top cover 20.00
oil pump used 20.00
