Single Turbo LS1 Notch Build *videos*
Old 01-19-2010, 11:03 PM
jdmotox333's Avatar
thank you thank you gave it the classic spit shine lol nah thank god the invention of scratch x 2.0 n gold class wax
Old 01-28-2010, 10:54 PM
bad6as's Avatar
more cutting. doing thru the floor subframe connectors. will tie in to front frame rails and either stop at the rear bulk head or ill tie it in to the rear torque boxes
pass side, all most done cutting
drivers side, still a little bit more cutting needed.
more parts keep showing up at the door,still lots to get, i sold the 31x12x3 intercooler for a 31x12x4 i hope that extra inch of thickness will help lower iats. meth will be used also. erik at hke said hes just waiting on my pushrods then the motor should ship out. still nothing from firefighting1101 on what hes gonna do about the trans bellhousing being broke (ultra bell best way to fix it imo) power coater sent me a pic of the wheel also.
the subframes will tie in to the rear frame so i needed to cut an opening threw the rear bulkhead
Old 02-05-2010, 12:54 PM
key4's Avatar
I really like those wheels. I wonder what it would look like on my car? Cant remember the color off hand but its light blue. I am seriously thinking about doing this now.
Old 02-14-2010, 09:28 PM
bad6as's Avatar
few minor up dates. i got a silicone elbow that i needed and i sold my 3" intercooler and got a 4" intercooler. looks so much bigger. so i connected the turbo to the intercooler.
Old 02-14-2010, 09:41 PM
MillsMotorvation's Avatar
Looks like it's going to be nice!!
Old 02-15-2010, 12:20 AM
needaz28's Avatar
nice! I just wrecked my 01 turbo ws6. swapping all that into a fox. what oan do you need to run? a custom steel one, or what?
thx!
Old 02-15-2010, 10:22 AM
protracracing's Avatar
where did you get the intercooler at?
Thanks
Dennis
Old 02-15-2010, 10:53 AM
boosteddakota's Avatar
looks good man
Old 02-18-2010, 11:57 PM
bad6as's Avatar
thx!
oil pan??? i used a 98-02 f-body
Thanks
Dennis
off ebay
GOT MY MOTOR!
update.
thru floor frame connectors are done!
battery box is mounted
made my own rear bumper support
getting the motor all buttond up, should be able to go in the car on sunday, then ill make the hot side and finish the cold side.
i got 80 some days till the ocean city show
Old 02-24-2010, 01:34 AM
2XR95Z28's Avatar
Lovin the build man! Someday my s10 will get a turbo set up... Keep up the good work!
Old 02-24-2010, 11:11 PM
bad6as's Avatar
motor put togeather
motor in car
th400 bolted to motor and in car
this look right?
under car pic
Old 03-03-2010, 11:50 AM
  #32
Spoolinsteve's Avatar
Looks amazing! Good luck with the build.
Old 03-03-2010, 05:52 PM
  #33
danbap's Avatar
very nice work keep the pics coming
Old 03-04-2010, 05:18 AM
  #34
Rare99SS's Avatar
Lookin good fellas. Can't wait to see this bad boy launchin at the track.
Old 03-04-2010, 03:34 PM
  #35
bad6as's Avatar
got more wiring out of the way, this time its hooking the engine harness up, and hooking up the ignition switch, all to work like it should. for fun i put the wheels and front clip back on and took a pic.
Old 03-04-2010, 04:08 PM
  #36
Double_Trouble99's Avatar
theres something about black cars and black wheels that gets me going! lol looks great.
Old 03-04-2010, 04:30 PM
  #37
orangenotch's Avatar
Looks good. Can't wait to get mine running n/a and then turbo it next year hopefully.
Old 03-05-2010, 09:27 AM
  #38
That thing looks sinister as hell
Old 03-23-2010, 01:58 PM
  #39
bad6as's Avatar
ultrabell installed on the th400
fuel pump mounted
fuel lines all most done
new flexplate bolted in and starter.
as it sits
Old 03-23-2010, 05:30 PM
  #40
danbap's Avatar
what year engine is that?(short or long crank) what flex plate did you use? did you have to use a spacer for it? the converter your using is it set up for a th400-ls1?
sorry for all the questions. I'm trying to figure out if i have the correct parts to put mine together with.
Quick Reply: Single Turbo LS1 Notch Build *videos*
