Info. on wire harness
Old Jan 23, 2010 | 08:12 PM
Micah Johnstone's Avatar
Smile Info. on wire harness
Just wondering does anyone have a good reliable source of information on how to convert a stock 5.3 truck harness?I know there is a lot to cut out and I am capable of doing the work myself just need to know what to keep and what to toss.I have one book from SA Design "How to swap Gm LS series engines into almost anything" they do have a section on it just don't know if it covers my engine it covers 1999-2002 LS1,was the 5.3 still considered a vortec or an LS1?
If anyone has some info or know where to look that would be greatly appreciated.
Thanks in advance.
Old Jan 23, 2010 | 08:25 PM
bronx_peanut's Avatar
Go to www.lt1swap.com there is tons of info on what to remove and to make your harness stand alone.
Old Jan 23, 2010 | 08:27 PM
G-Body's Avatar
sawzall wielding director
Best thing is to get a set of wiring diagams for the harness and check it out for yourself. There is somewhat of a how-to in the FAQ sticky, but in reality each swap is going to be different. There should also be some pin-outs in the FAQ sticky.
Old Jan 23, 2010 | 08:34 PM
The swap is going into a 62 impala wagon,i am using a 18 circuit painless chassis harness so somehow i will have to mate the two together?I have read there is'nt that many wire to mate.
thanks
Old Jan 23, 2010 | 08:44 PM
So is the LS1 5.7 pinouts going to be the same for my 5.3 I dont think so??Anyone have pinouts for a 5.3 truck harness.
thanks again sounds like stupid questions but I am new at this.
Old Jan 23, 2010 | 09:00 PM
rojs234's Avatar
[QUOTE=Micah Johnstone;12791678]So is the LS1 5.7 pinouts going to be the same for my 5.3 I dont think so??Anyone have pinouts for a 5.3 truck harness.
thanks again sounds like stupid questions but I am new at this.[/QUOTE
Do what *bronx_peanut* told you and go to www.lt1swap.com. THEN READ IT. He has the truck pin outs and the instructions to do what you want to do.
Old Jan 23, 2010 | 09:01 PM
Chill out have'nt got that far.
Thanks
Old Jan 23, 2010 | 10:57 PM
G-Body's Avatar
The 5.3L truck and 5.7 LS1 are different. the 99-02 truck 5.3L and LS1 both use the same computer and very similar pinouts for it. However, the wiring harness is different and has differently labeled connectors. So you will need 5.3L information.
Old Jan 23, 2010 | 11:51 PM
Thanks G-body,The other guys were right LT1 swap has fantastic info..I will probably start there then slowly bring up more questions as i have them.
thanks again
